1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: MVME3100 boot failure at "Trying to find CSR on VME"
From: Peter Linardakis via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 2 Dec 2021 01:20:51 +0000
Hi all
Thank you all for the input.  I've been trying different combinations without much success.  There are other cards in the crate but the behaviour is the same whether there are none, some or all cards inserted.  We have other similarly configured crates and the DIP switch settings match.  Since three MVME3100 units display the same behaviour in that crate, but get past that boot stage in another crate/backplane, the only thing I can think of is that we may have damaged the backplane?  Does an MVME3100 theoretically even need a backplane to get past that boot stage?
Regards
Peter
-----Original Message-----
Sent: Wednesday, 1 December 2021 3:09 AM
To: Johnson, Andrew N. <[email protected]>; Peter Linardakis <[email protected]>
Subject: Re: MVME3100 boot failure at "Trying to find CSR on VME"
On 11/30/21 7:05 AM, Johnson, Andrew N. wrote:
> On Nov 29, 2021, at 8:33 PM, Michael Davidsaver via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
>> On 11/28/21 9:12 PM, Peter Linardakis via Tech-talk wrote:
>>> vmeTsi148 IRQ manager: looking for registers on VME...
>>> Trying to find CSR on VME...
>>> Does anyone have any ideas why a certain backplane will cause this?
>> CSR in this context refers to the CSR address space, which is a VME64
>> extension using the geographic address pins, which won't be present
>> in an older VME32 crate.
>> Still, this error shouldn't be fatal as the TSI148 driver should fall
>> back and print "Trying to find CRG on VME...".
>> https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgit
>> hub.com%2FRTEMS%2Frtems%2Fblob%2Fe945e3fc4d6a6a74789c9a348120ec7d06e1
>> 9231%2Fbsps%2Fpowerpc%2Fshared%2Fvme%2FvmeTsi148.c%23L1715&amp;data=0
>> 4%7C01%7Cpeter.linardakis%40anu.edu.au%7Cc0b7a358faa84bbe6a1c08d9b41b
>> c1c7%7Ce37d725cab5c46249ae5f0533e486437%7C0%7C0%7C637738854022347930%
>> 7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6I
>> k1haWwiLCJXVCI6Mn0%3D%7C3000&amp;sdata=BkfYhyq83jjPQ2dBF9F5fiKLGIzOub
>> xxbAtOSuIu3jk%3D&amp;reserved=0
>> <https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgi
>> thub.com%2FRTEMS%2Frtems%2Fblob%2Fe945e3fc4d6a6a74789c9a348120ec7d06e
>> 19231%2Fbsps%2Fpowerpc%2Fshared%2Fvme%2FvmeTsi148.c%23L1715&amp;data=
>> 04%7C01%7Cpeter.linardakis%40anu.edu.au%7Cc0b7a358faa84bbe6a1c08d9b41
>> bc1c7%7Ce37d725cab5c46249ae5f0533e486437%7C0%7C0%7C637738854022347930
>> %7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6
>> Ik1haWwiLCJXVCI6Mn0%3D%7C3000&amp;sdata=BkfYhyq83jjPQ2dBF9F5fiKLGIzOu
>> bxxbAtOSuIu3jk%3D&amp;reserved=0>
> Since the CPU on this backplane apparently hangs before printing that "CRG" message, my guess is that either the VME system controller isn't generating a BERR signal if/when nothing responds to the I/O cycle after some suitable timeout interval (I assume from the probe operation in the call at line 1717), or maybe that the backplane has a problem with its BERR* signal line not working properly (is it terminated properly?). If the CPU doesn't see a falling edge on either the BERR or DTACK signal it will hang waiting for a data from the read cycle which never completes. If this CPU *is* the VME system controller the code should have enabled a cycle timeout, but going back to what Heinz was talking about you need to make sure that the SCON is properly enabled and that the CPU is in slot 0.
For what little it is worth, I once successfully setup a mvme3100 with RTEMS (4.9.x) in an old (antique?) VME32 crate.  However, that was 10 years ago and I don't now recall what all I had to do.
wrt. SCON there are a pair of DIP switches in the S4 bank which can be set to force a mvme3100 to be SCON.
see sections 1.4.2 and 1.4.3.
https://aus01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.slac.stanford.edu%2Fgrp%2Flcls%2Fcontrols%2Fglobal%2Fhw%2Fusers_guides%2Fvme%2Fcpu%2Fmvme3100%2FMVME3100-programmer-ref.pdf&amp;data=04%7C01%7Cpeter.linardakis%40anu.edu.au%7Cc0b7a358faa84bbe6a1c08d9b41bc1c7%7Ce37d725cab5c46249ae5f0533e486437%7C0%7C0%7C637738854022357890%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000&amp;sdata=7tDbebKF%2B8ch5RLLVxWIt7deApqdtl1H%2FJFeDs73s9g%3D&amp;reserved=0
Re: MVME3100 boot failure at "Trying to find CSR on VME" Michael Davidsaver via Tech-talk
Re: MVME3100 boot failure at "Trying to find CSR on VME" Johnson, Andrew N. via Tech-talk
MVME3100 boot failure at "Trying to find CSR on VME" Peter Linardakis via Tech-talk
Prev: Re: asynUSBTMC communications issue Eric Norum via Tech-talk
Next: RE: CA Gateway same VM as IOCs/Phoebus and Access/PVList Setup Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: MVME3100 boot failure at "Trying to find CSR on VME" Michael Davidsaver via Tech-talk
Next: Re: MVME3100 boot failure at "Trying to find CSR on VME" Michael Davidsaver via Tech-talk
