1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Trying to use elauncher: _main_ thread failed
From: "Crisp, Daniel via Tech-talk" <[email protected]>
To: "Hu, Yong" <[email protected]>, "[email protected]" <[email protected]>, "[email protected]" <[email protected]>
Cc: "Barofsky, Daniel" <[email protected]>
Date: Tue, 7 Dec 2021 19:13:16 +0000
Ah, I hadn't realized it was davidsaver who'd made this one too. I knew he'd developed pydevsup, which I use elsewhere.
So I did declare the bo correctly, but realized I was still getting the error even when I removed my .db file with the launcher bo. It was as if it was looking for @python ... or info(cmd, "...") for all my non-launcher bo's too. Turns out it was the order in which I added lines to my src/Makefile that was the issue. <myioc>_DBD+= had to be grouped with similar lines. It now seems to be working.
Thank you for the link Yong! I couldn't find anything when I searched for more information.
Sent: Tuesday, December 7, 2021 11:46:06 AM
To: Crisp, Daniel; [email protected]
Cc: Barofsky, Daniel
[EXTERNAL] This email originated from outside of FRIB
That program was developed by Michael Davidsaver at NSLS-2 many years ago. How do you load you *.db file in your st.cmd? You need a ‘bo’ record similar to this:
https://github.com/NSLS-II/elauncher/blob/main/elauncherApp/Db/elauncher.db
Yong
From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
Reply-To: "Crisp, Daniel" <[email protected]>
Date: Monday, December 6, 2021 at 4:04 PM
Subject: Trying to use elauncher: _main_ thread failed
I don't see much documentation about what we call 'elauncher' here, so I'm thinking it might be something site specific? In any case, It's what we use to add PVs that trigger python scripts to our IOCs. I've attached the source code we add to our src/ folder. We also have an elaunchSupport.dbd file that simply contains two lines 'device(bo, INST_IO, devLauncher, "Launcher")'' and 'variable(launcherVerbose, int)'.
I'm getting an error when attempting to start the IOC, and I'm wondering if someone here could enlighten me as to the problem:
A call to 'assert(prec->out.type == INST_IO)' by thread '_main_' failed in ../launcher.c line 80.
Dumping a stack trace of thread '_main_':
[    0x7f95a3285283]: /lib/x86_64-linux-gnu/libCom.so.3.15.8(epicsStackTrace+0x73)
[    0x7f95a327e7af]: /lib/x86_64-linux-gnu/libCom.so.3.15.8(epicsAssert+0x4f)
[    0x5604d5f29b2f]: ../../bin/linux-x86_64/hlc_s800(add_record+0x4f)
[    0x7f95a3309ea7]: /lib/x86_64-linux-gnu/libdbCore.so.3.15.8(coreRelease+0x837)
[    0x7f95a330a10a]: /lib/x86_64-linux-gnu/libdbCore.so.3.15.8(iocBuild+0x1a)
[    0x7f95a330a299]: /lib/x86_64-linux-gnu/libdbCore.so.3.15.8(iocInit+0x9)
[    0x7f95a32700fb]: /lib/x86_64-linux-gnu/libCom.so.3.15.8(gphDump+0x125b)
[    0x5604d5f1fea2]: ../../bin/linux-x86_64/hlc_s800(main+0x12)
[    0x7f95a309e09b]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb)
[    0x5604d5f1fefa]: ../../bin/linux-x86_64/hlc_s800(_start+0x2a)
EPICS Release EPICS R3.15.8-2+0~20201111173402.6+debian10~1.gbp133abb.
Local time is 2021-12-04 14:33:29.880008830 EST
Please E-mail this message to the author or to [email protected] epicsThreadSuspendSelf()
Trying to use elauncher: _main_ thread failed Crisp, Daniel via Tech-talk
Re: Trying to use elauncher: _main_ thread failed Hu, Yong via Tech-talk
Prev: Re: Need clarification on UDP Broadcasting to multiple IOCs on same PC Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] How to put the contents of a file in a waveform record Vodopivec, Klemen via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Trying to use elauncher: _main_ thread failed Hu, Yong via Tech-talk
Next: FLIR Camera with AD Spinnaker losses ID Smith, William via Tech-talk
