1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: arv-tools not detecting USB3 camera
From: "Gofron, Kazimierz via Tech-talk" <[email protected]>
To: "Engbretson, Mark S." <[email protected]>
Cc: "[email protected] \([email protected]\)" <[email protected]>
Date: Mon, 13 Dec 2021 21:58:54 +0000
Hi Mark,
I am not sure if USB3 dependency is compiled in. Frankly, I am not sure how to check it. I looked at meson-log.txt, and it confirms it by looking for  'libusb-1.0' package, which exists on debian, but not on RedHat (to my knowledge). I might be wrong here.
In meson-log.txt
"Preliminary CMake check failed. Aborting.
Run-time dependency libusb-1.0 found: NO (tried pkgconfig and cmake)"
"Called `/usr/bin/cmake --trace-expand --trace-format=json-v1 --no-warn-unused-cli --trace-redirect=cmake_trace.txt .` in /epics/src/modules/aravis/build/meson-private/cmake_libusb-1.0 -> 0
  -- Module search paths:    ['/', '/opt', '/usr', '/usr/local']
  -- CMake root:             /usr/share/cmake
  -- CMake architectures:    []
  -- CMake lib search paths: ['lib', 'lib32', 'lib64', 'libx32', 'share']
That indicates that it is looking for libusb-1.0 package, which to my knowledge does not exist on RedHat.
So maybe USB3 support is not compiled in, because libusb-1.0 does not exist (to my knowledge) on redhat.
Kaz
Sent: Monday, December 13, 2021 1:59 PM
To: Gofron, Kazimierz <[email protected]>
Cc: [email protected] ([email protected]) <[email protected]>
Subject: RE: arv-tools not detecting USB3 camera
Is the version of aravis that you are using built with the USB3 support enabled?
Sent: Monday, December 13, 2021 12:56 PM
To: Engbretson, Mark S. <[email protected]>
Hi Mark,
Good point, and I did not install aravis udev rules yet.
However, when arv-tools is run as root, it does not detect the USB3 camera either.
[root@xf11id-m3 ~]# arv-tool-0.8 -d all
[11:52:14.710]
🅸 interface> [GvDiscoverSocket::new] Add interface 127.0.0.1 (127.0.0.1)
[11:52:14.710]
🅸 interface> [GvDiscoverSocket::new] Add interface 192.168.11.1 (192.168.11.255)
[11:52:14.710]
🅸 interface> [GvDiscoverSocket::new] Add interface 10.69.24.152 (10.69.24.255)
[11:52:14.711]
🅸 interface> [GvDiscoverSocket::new] Add interface 10.66.83.36 (10.66.83.255)
[11:52:14.711]
🅸 interface> [GvDiscoverSocket::new] Add interface 192.168.122.1 (192.168.122.255)
[11:52:14.712]
🅸 interface> [GvInterface::discovery] Device 'Point Grey Research-Blackfly BFLY-PGE-50S5C-18457368' found (interface 192.168.11.1) user_id '' - MAC '00:b0:9d:19:a3:18'
[11:52:14.712]
🅸 interface> [GvInterface::discovery] Device 'Point Grey Research-Blackfly BFLY-PGE-50S5C-18481534' found (interface 192.168.11.1) user_id '' - MAC '00:b0:9d:1a:01:7e'
Point Grey Research-Blackfly BFLY-PGE-50S5C-18457368 (192.168.11.11)
Point Grey Research-Blackfly BFLY-PGE-50S5C-18481534 (192.168.11.12)
Something else is missing on RedHat...
Kaz
Sent: Monday, December 13, 2021 1:11 PM
Do you have the aravis udev rules installed so that non root accounts can actually see the usb3 hardware?
From: Tech-talk <[email protected]> On Behalf Of Gofron, Kazimierz via Tech-talk
Sent: Monday, December 13, 2021 12:00 PM
To: [email protected]
Subject: arv-tools not detecting USB3 camera
I have a USB3 Grasshopper3 GS3-U3-51S5C camera that arv-tools-0.8 is not detecting.
The GS3-U3-51S5C supports USB3 Vision v1.0,
OS: Redhat 8.4
{Aravis detects only my GigE cameras:}
kgofron@xf11id-m3:/epics/iocs$ arv-tool-0.8
{arv-tools with options does not list usb camera either}
kgofron@xf11id-m3:/epics/iocs$ arv-tool-0.8 -d all
[15:02:46.093] ?? interface> [GvDiscoverSocket::new] Add interface 127.0.0.1 (127.0.0.1)
{The camera shows up in libusb and /dev/bus/usb, but is not found by arv-tool:}
kgofron@xf11id-m3:/epics/iocs/cam-aravis1$ lsusb
Bus 002 Device 003: ID 1e10:3300 Point Grey Research, Inc.
kgofron@xf11id-m3:/epics/iocs$ ls /dev/bus/usb/002/003
{USB camera is on bus 002 device 003}
Camera details:
kgofron@xf11id-m3:/dev/bus/usb/002$ usb-devices
T:  Bus=02 Lev=01 Prnt=01 Port=02 Cnt=01 Dev#=  3 Spd=5000 MxCh= 0
D:  Ver= 3.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS= 9 #Cfgs=  1
P:  Vendor=1e10 ProdID=3300 Rev=00.00
S:  Manufacturer=Point Grey Research
S:  Product=Grasshopper3 GS3-U3-51S5C
S:  SerialNumber=0123EF71
C:  #Ifs= 3 Cfg#= 1 Atr=80 MxPwr=896mA
I:  If#=0x0 Alt= 0 #EPs= 2 Cls=ef(misc ) Sub=05 Prot=00 Driver=(none)
I:  If#=0x1 Alt= 0 #EPs= 1 Cls=ef(misc ) Sub=05 Prot=01 Driver=(none)
I:  If#=0x2 Alt= 0 #EPs= 1 Cls=ef(misc ) Sub=05 Prot=02 Driver=(none)
USB support is installed:
libusb-devel.x86_64
libusbx-devel.x86_64
Any suggestions about this problem?
Kazimierz Gofron
RE: arv-tools not detecting USB3 camera Mark Rivers via Tech-talk
arv-tools not detecting USB3 camera Gofron, Kazimierz via Tech-talk
RE: arv-tools not detecting USB3 camera Engbretson, Mark S. via Tech-talk
Re: arv-tools not detecting USB3 camera Gofron, Kazimierz via Tech-talk
Prev: RE: arv-tools not detecting USB3 camera Mark Rivers via Tech-talk
Next: RE: arv-tools not detecting USB3 camera Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
