So my conclusion is that giving this limitation of 256 chars of maclib parser,
It is wise then to never use EPICS_DB_INCLUDE_PATH in a snippet to add
local db path, since if you have a long list of require you may hit into trouble.
So, indirectly, this is related to ESS's E3 development environment that keeps all dependency modules in separate locations (with long paths). Using other environments and/or deployment mechanisms that don't allow parallel use of multiple versions of modules, shared things get installed into a single location, so your EPICS_DB_INCLUDE_PATH stays as short as "$(TOP)/db:$(SHARED)/db".
Cheers, ~Ralph
- Re: EPICS_DB_INCLUDE_PATH Michael Davidsaver via Tech-talk
- EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
- RE: EPICS_DB_INCLUDE_PATH Alfio Rizzo via Tech-talk
AW: Photonic Science X-ray FDS camera Sintschuk, Michael via Tech-talk
CA Gateway 2.1.3 released Ralph Lange via Tech-talk
<2021>
2025
<2021>
2025
ANJ, 15 Dec 2021 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
