1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: CA Gateway 2.1.3 released
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 15 Dec 2021 14:40:07 +0100
Dear all,
Release 2.1.3 of the CA Gateway is available on its GitHub release page [1]
From the release notes:
  • Small fixes in caPutLog support
  • Fix a bug (#33) where array values were lost (except the first element) on subscriptions after a read request for a container type
  • Fix update of enum labels on active subscriptions using a container type
  • A bug that interprets doubles (written as strings) as hex numbers (#37) is fixed when the Gateway is linked against PCAS >= 4.13.3 or Base 3.15 >= 3.15.10
This update is recommended for productional Gateways.
Please make sure to use PCAS >= 4.13.3 with Base 7.0 (recommended) or Base 3.15 >= 3.15.10 (not released yet) to have #37 fixed.
Bug reports and Pull Requests are always welcome.
The tests are in a weird state: Continuous integration on GitHub Actions shows segfaults in the test code, while locally the tests pass. This seems to be related to the test code more than to the Gateway code.
Thanks to the contributors, especially Sebastian Marsching,
~Ralph
Prev: Re: EPICS_DB_INCLUDE_PATH Ralph Lange via Tech-talk
Next: Re: Photonic Science X-ray FDS camera Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Camera parameters not writable in ADAravis Mark Rivers via Tech-talk
Next: netDev v1.1.0 released Shuei YAMADA via Tech-talk
