1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Reliability of caput
From: "Wang, Andrew via Tech-talk" <[email protected]>
To: "J. Lewis Muir" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Tue, 21 Dec 2021 02:33:51 +0000
Hi Lewis,
Sorry if I wasn't clear. Basically if I run both caput commands with no wait period in between, will I expect to see 100 in A and 200 in B when I run caget.
A and B are separate records. There is no forward linking between them. They are the only records in the database file and are both passive.
-----Original Message-----
Sent: Monday, December 20, 2021 6:31 PM
To: Wang, Andrew <[email protected]>
Subject: Re: Reliability of caput
On 12/21, Wang, Andrew via Tech-talk wrote:
> Quick question.
> Suppose I have two analog input records called "A" and "B" on which I would like to do caput. If I have a bash script containing the following code:
> caput A 100
> caput B 200
> Will that give sufficient time for caput to respond?
Respond to what?  What do you mean by "respond"?
> Or should there ideally be a "delay" between each caput. The reason why I ask is because within the sequencer, we do something similar, but with pvPut, and sometimes we see that "B" does not get updated with a new value.
How are A and B related?
Lewis
Re: Reliability of caput J. Lewis Muir via Tech-talk
Reliability of caput Wang, Andrew via Tech-talk
Prev: Re: Reliability of caput J. Lewis Muir via Tech-talk
Next: Re: Reliability of caput J. Lewis Muir via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
