1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Reliability of caput
From: "J. Lewis Muir via Tech-talk" <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 20 Dec 2021 21:27:07 -0600
On 12/21, Wang, Andrew wrote:
> Sorry if I wasn't clear. Basically if I run both caput commands with no wait period in between, will I expect to see 100 in A and 200 in B when I run caget.
> A and B are separate records. There is no forward linking between them. They are the only records in the database file and are both passive.
OK, so your Bash script would contain the following?
caput A 100
caput B 200
caget A
caget B
What is DTYP of each ai record set to?  Or is it not set?  If not set,
it would normally default to "Soft Channel".
If that's the case, I think most of the time it will work as you expect
without a delay, but I think you are not guaranteed that caget will
return 100 for A and 200 for B because the CA puts from the caput
commands could still be executing when the caget commands run.  (But
I could be wrong about this; I haven't looked at the ai record source
code.  An EPICS developer would know and can correct me if I'm wrong.)
However, I think what would guarantee the happens-after relationship
that you want for the caget commands is to make the caput commands
synchronous by using the "-c" and "-w <sec>" options.  The "caput
-h" help output is a little confusing, IMO, in that it calls it
an "asynchronous put" where it says, "-c: Asynchronous put (use
ca_put_callback and wait for completion)," when what you're really
getting is synchronous behavior for the caput program: it will wait for
the CA put to complete before exiting.  Anyway, assuming you're OK for
the caput commands to wait, I think that would do what you want, so:
caput -c -w 15 A 100
caput -c -w 15 B 200
caget A
caget B
Lewis
Reliability of caput Wang, Andrew via Tech-talk
Re: Reliability of caput J. Lewis Muir via Tech-talk
RE: Reliability of caput Wang, Andrew via Tech-talk
Prev: RE: Reliability of caput Wang, Andrew via Tech-talk
Next: Re: Reliability of caput Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
