Dear community,
I'm writing to see if you can help me to solve a problem I'm doing a migrating the "PMAC-VME Device Driver" to EPCIS version 7.0.6.1. with rtems5. The driver is working for EPCIS version 3.14.8 and RTEMS 4.10. The code compiles perfectly for Epics 7 and rtems5, but when I deploy it on the MVM2700 LCU, I get the following error: Error code 30 (INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL). The RTEMS documentation describes the error as follows: It is illegal to call blocking operating system services with thread dispatching disabled, for example in interrupt context. I attach the Stack Trace at the end of the sms. I have run addr2line to get more information and you can give me suggestions on how I might fix the problem. Thanks in advance for your help. In the following table, I have put the first group of "Stack Trace" for easier reading. I copy below the code fragment of the "PMAC-VME Device Driver" referring to the line marked in bold in the table. static int mbxRcptISRcnt = 0; PMAC_LOCAL void pmacMbxReceiptISR(void *p) { PMAC_CTLR *pPmacCtlr = (PMAC_CTLR *)p; cntRxISR++; epicsEventSignal (pPmacCtlr->ioMbxReceiptSem); mbxRcptISRcnt++; // line 130 of the drvPmacVme.c file. return; } After the table, I attach the Stack Trace output and the ADDR2LINE output. Stack Trace fatal source: 0 (INTERNAL_ERROR_CORE) fatal code: 30 (INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL) RTEMS version: 5.0.0.645dbc5fccd8b73e12ca17ab35962fe751854913 RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (803d42cda7b3), Newlib 7947581) executing thread ID: 0x08b010010 executing thread name: Printing a stack trace for your convenience :-) *** FATAL *** fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION) exception vector 3 (0x3) next PC or address of fault = 0x0025cb8c saved MSR = 0x00001032 context = interrupt, ISR nest level = 1 thread dispatch disable level = 2 R0 = 0x00254f84 R1 = 0x00494758 R2 = 0x00000000 R3 = 0x00000030 R4 = 0x00000000 R5 = 0x002bca1c R6 = 0x004947b0 R7 = 0x0025dd08 R8 = 0x004947a0 R9 = 0xa5a5a5a5 R10 = 0x004947a0 R11 = 0x00000000 R12 = 0x40842402 R13 = 0x003006c0 R14 = 0x00ef1640 R15 = 0x00000000 R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000 R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000 R24 = 0x00336560 R25 = 0x00000000 R26 = 0x002a41b0 R27 = 0x00135580 R28 = 0x004948a8 R29 = 0x00494760 R30 = 0x0000001e R31 = 0x003174e8 CR = 0x40842408 CTR = 0x00000017 XER = 0x20000000 LR = 0x00254f88 DAR = 0xa5a5a5a9 executing thread ID = 0x0b010010, name = Stack Trace: IP: 0x0025cb8c, LR: 0x00254f88 --^ 0x00254f84--^ 0x00254ec4--^ 0x00135648--^ 0x00135854--^ 0x001358ac --^ 0x001321f4--^ 0x0012aa4c--^ 0x0010b08c--^ 0x001039e8--^ 0x000f502c --^ 0x000fd6cc--^ 0x0001360c--^ 0x0025f628--^ 0x00262f64--^ 0x0025dd08 *** FATAL *** fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION) exception vector 3 (0x3) next PC or address of fault = 0x0025d240 saved MSR = 0x00001032 context = interrupt, ISR nest level = 1 thread dispatch disable level = 2 R0 = 0x0025d270 R1 = 0x004945e8 R2 = 0x00000000 R3 = 0x002bdd8c R4 = 0x00000000 R5 = 0x002784e8 R6 = 0x00494578 R7 = 0x002784ea R8 = 0x002784e9 R9 = 0xa5a5a5a5 R10 = 0x800003fd R11 = 0x00000000 R12 = 0x40442202 R13 = 0x003006c0 R14 = 0x004946a8 R15 = 0x00000000 R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000 R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000 R24 = 0x00336560 R25 = 0x00000000 R26 = 0x002a41b0 R27 = 0x002784e8 R28 = 0xcccccccd R29 = 0x002bdd8c R30 = 0x00494a10 R31 = 0x00000010 CR = 0x40442808 CTR = 0x00254fe8 XER = 0x20000000 LR = 0x0025d270 DAR = 0xa5a5a5a9 executing thread ID = 0x0b010010, name = Stack Trace: IP: 0x0025d240, LR: 0x0025d270 --^ 0x00254f64--^ 0x00135648--^ 0x00135854--^ 0x002662f0--^ 0x0025de68 --^ 0x40842402--^ 0x00254f84--^ 0x00254ec4--^ 0x00135648--^ 0x00135854 --^ 0x001358ac--^ 0x001321f4--^ 0x0012aa4c--^ 0x0010b08c--^ 0x001039e8 --^ 0x000f502c--^ 0x000fd6cc--^ 0x0001360c--^ 0x0025f628--^ 0x00262f64 --^ 0x0025dd08 ADDR2LINE line to Analyzed 0x00254f84 0x00254ec4 0x00135648 0x00135854 0x001358ac ADDR: 0x00254f84 -> bsp_reset /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/lib/libbsp/powerpc/motorola_powerpc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/motorola_powerpc/../../../../../../bsps/powerpc/motorola_powerpc/start/bspreset.c:16 ADDR: 0x00254ec4 -> bsp_fatal_extension /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/lib/libbsp/powerpc/motorola_powerpc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/motorola_powerpc/../../../../../../bsps/shared/start/bspfatal-default.c:99 ADDR: 0x00135648 -> _User_extensions_Iterate /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/userextiterate.c:172 ADDR: 0x00135854 -> _Terminate /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/interr.c:38 ADDR: 0x001358ac -> _Workspace_Handler_initialization /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/wkspace.c:54 line to Analyzed 0x001321f4 0x0012aa4c 0x0010b08c 0x001039e8 0x000f502c ADDR: 0x001321f4 -> _Thread_Dispatch_enable /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/threaddispatch.c:364 ADDR: 0x0012aa4c -> _POSIX_Get_error /gem_base/targetOS/RTEMS/rtems/kernel/rtems/cpukit/include/rtems/posix/posixapi.h:70 ADDR: 0x0010b08c -> epicsEventWait /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../osi/os/posix/osdEvent.c:105 ADDR: 0x001039e8 -> epicsEventMustWait /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../osi/epicsEvent.cpp:127 ADDR: 0x000f502c -> errlogFlush /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../error/errlog.c:551 line to Analyzed 0x000fd6cc 0x0001360c 0x0025f628 0x00262f64 0x0025dd08 ADDR: 0x000fd6cc -> cantProceed /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../misc/cantProceed.c:69 ADDR: 0x0001360c -> pmacMbxReceiptISR /home/framos/work/pmaclib.git/pmaclibApp/src/O.RTEMS-mvme2700/../drvPmacVme.c:130 ADDR: 0x0025f628 -> universeVMEISR /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/lib/libbsp/powerpc/motorola_powerpc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/motorola_powerpc/../../../../../../bsps/powerpc/shared/vme/vmeUniverse.c:1978 ADDR: 0x00262f64 -> bsp_interrupt_handler_dispatch /gem_base/targetOS/RTEMS/rtems/kernel/rtems/bsps/include/bsp/irq-generic.h:274 ADDR: 0x0025dd08 -> wrap_change_msr_done_std /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/lib/libbsp/powerpc/motorola_powerpc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/motorola_powerpc/../../../../../../bsps/powerpc/shared/exceptions/ppc_exc.S:129 line to Analyzed line to Analyzed 0x00254f64 0x00135648 0x00135854 0x002662f0 0x0025de68 ADDR: 0x00254f64 -> rtems_exception_frame_print /gem_base/targetOS/RTEMS/rtems/kernel/rtems/cpukit/include/rtems/fatal.h:60 ADDR: 0x00135648 -> _User_extensions_Iterate /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/userextiterate.c:172 ADDR: 0x00135854 -> _Terminate /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/interr.c:38 ADDR: 0x001358ac -> _Workspace_Handler_initialization /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/wkspace.c:54 line to Analyzed 0x001321f4 0x0012aa4c 0x0010b08c 0x001039e8 0x000f502c ADDR: 0x001321f4 -> _Thread_Dispatch_enable /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/threaddispatch.c:364 ADDR: 0x0012aa4c -> _POSIX_Get_error /gem_base/targetOS/RTEMS/rtems/kernel/rtems/cpukit/include/rtems/posix/posixapi.h:70 ADDR: 0x0010b08c -> epicsEventWait /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../osi/os/posix/osdEvent.c:105 ADDR: 0x001039e8 -> epicsEventMustWait /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../osi/epicsEvent.cpp:127 ADDR: 0x000f502c -> errlogFlush /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../error/errlog.c:551 line to Analyzed 0x000fd6cc 0x0001360c 0x0025f628 0x00262f64 0x0025dd08 ADDR: 0x000fd6cc -> cantProceed /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../misc/cantProceed.c:69 ADDR: 0x0001360c -> pmacMbxReceiptISR /home/framos/work/pmaclib.git/pmaclibApp/src/O.RTEMS-mvme2700/../drvPmacVme.c:130 ADDR: 0x0025f628 -> universeVMEISR /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/lib/libbsp/powerpc/motorola_powerpc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/motorola_powerpc/../../../../../../bsps/powerpc/shared/vme/vmeUniverse.c:1978 ADDR: 0x00262f64 -> bsp_interrupt_handler_dispatch /gem_base/targetOS/RTEMS/rtems/kernel/rtems/bsps/include/bsp/irq-generic.h:274 ADDR: 0x0025dd08 -> wrap_change_msr_done_std /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/lib/libbsp/powerpc/motorola_powerpc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/motorola_powerpc/../../../../../../bsps/powerpc/shared/exceptions/ppc_exc.S:129 Regards,
ANJ, 14 Sep 2022 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
