Sorry send the wrong link.
This one might fitbetter : https://github.com/epics-base/epics-base/issues/202
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 12. Jan 2022, at 15:24, Francisco Ramos via Tech-talk <[email protected]> wrote:
> Dear community,
> I'm writing to see if you can help me to solve a problem I'm doing a migrating the "PMAC-VME Device Driver" to EPCIS version 7.0.6.1. with rtems5. The driver is working for EPCIS version 3.14.8 and RTEMS 4.10.
> The code compiles perfectly for Epics 7 and rtems5, but when I deploy it on the MVM2700 LCU, I get the following error: Error code 30 (INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL). The RTEMS documentation describes the error as follows:
> INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL (30)
> It is illegal to call blocking operating system services with thread dispatching disabled, for example in interrupt context.
> I attach the Stack Trace at the end of the sms.
> I have run addr2line to get more information and you can give me suggestions on how I might fix the problem. Thanks in advance for your help.
> In the following table, I have put the first group of "Stack Trace" for easier reading. I copy below the code fragment of the "PMAC-VME Device Driver" referring to the line marked in bold in the table.
> static int mbxRcptISRcnt = 0;
> PMAC_LOCAL void pmacMbxReceiptISR(void *p)
> PMAC_CTLR *pPmacCtlr = (PMAC_CTLR *)p;
> cntRxISR++;
> epicsEventSignal (pPmacCtlr->ioMbxReceiptSem);
> mbxRcptISRcnt++; // line 130 of the drvPmacVme.c file.
> return;
> After the table, I attach the Stack Trace output and the ADDR2LINE output.
> ADDR function File And Line
> 0x00254f84 bsp_reset /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/lib/libbsp/powerpc/motorola_powerpc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/motorola_powerpc/../../../../../../bsps/powerpc/motorola_powerpc/start/bspreset.c:16
> 0x00254ec4 bsp_fatal_extension /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/lib/libbsp/powerpc/motorola_powerpc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/motorola_powerpc/../../../../../../bsps/shared/start/bspfatal-default.c:99
> 0x00135648 _User_extensions_Iterate /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/userextiterate.c:172
> 0x00135854 _Terminate /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/interr.c:38
> 0x001358ac _Workspace_Handler_initialization /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/wkspace.c:54
> 0x001321f4 _Thread_Dispatch_enable /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/cpukit/../../../../../rtems/c/src/../../cpukit/score/src/threaddispatch.c:364
> 0x0012aa4c _POSIX_Get_error /gem_base/targetOS/RTEMS/rtems/kernel/rtems/cpukit/include/rtems/posix/posixapi.h:70
> 0x0010b08c epicsEventWait /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../osi/os/posix/osdEvent.c:105
> 0x001039e8 epicsEventMustWait /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../osi/epicsEvent.cpp:127
> 0x000f502c errlogFlush /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../error/errlog.c:551
> 0x000fd6cc cantProceed /builddir/build/BUILD/epics-base-git-13.a417dec/modules/libcom/src/O.RTEMS-mvme2700/../misc/cantProceed.c:69
> 0x0001360c pmacMbxReceiptISR /home/framos/work/pmaclib.git/pmaclibApp/src/O.RTEMS-mvme2700/../drvPmacVme.c:130
> 0x0025f628 universeVMEISR /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/lib/libbsp/powerpc/motorola_powerpc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/motorola_powerpc/../../../../../../bsps/powerpc/shared/vme/vmeUniverse.c:1978
> 0x00262f64 bsp_interrupt_handler_dispatch /gem_base/targetOS/RTEMS/rtems/kernel/rtems/bsps/include/bsp/irq-generic.h:274
> 0x0025dd08 wrap_change_msr_done_std /gem_base/targetOS/RTEMS/rtems/kernel/mvme2307/powerpc-rtems5/c/mvme2307/lib/libbsp/powerpc/motorola_powerpc/../../../../../../../../rtems/c/src/lib/libbsp/powerpc/motorola_powerpc/../../../../../../bsps/powerpc/shared/exceptions/ppc_exc.S:129
> Stack Trace
> fatal source: 0 (INTERNAL_ERROR_CORE)
> fatal code: 30 (INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL)
> RTEMS version: 5.0.0.645dbc5fccd8b73e12ca17ab35962fe751854913
> RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (803d42cda7b3), Newlib 7947581)
> executing thread ID: 0x08b010010
> executing thread name:
> Printing a stack trace for your convenience :-)
> *** FATAL ***
> fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
> exception vector 3 (0x3)
> next PC or address of fault = 0x0025cb8c
> saved MSR = 0x00001032
> context = interrupt, ISR nest level = 1
> thread dispatch disable level = 2
> R0 = 0x00254f84 R1 = 0x00494758 R2 = 0x00000000 R3 = 0x00000030
> R4 = 0x00000000 R5 = 0x002bca1c R6 = 0x004947b0 R7 = 0x0025dd08
> R8 = 0x004947a0 R9 = 0xa5a5a5a5 R10 = 0x004947a0 R11 = 0x00000000
> R12 = 0x40842402 R13 = 0x003006c0 R14 = 0x00ef1640 R15 = 0x00000000
> R16 = 0x00000000 R17 = 0x00000000 R18 = 0x00000000 R19 = 0x00000000
> R20 = 0x00000000 R21 = 0x00000000 R22 = 0x00000000 R23 = 0x00000000
> R24 = 0x00336560 R25 = 0x00000000 R26 = 0x002a41b0 R27 = 0x00135580
> R28 = 0x004948a8 R29 = 0x00494760 R30 = 0x0000001e R31 = 0x003174e8
> CR = 0x40842408
> CTR = 0x00000017
> XER = 0x20000000
> LR = 0x00254f88
> DAR = 0xa5a5a5a9
> executing thread ID = 0x0b010010, name =
> Stack Trace:
> IP: 0x0025cb8c, LR: 0x00254f88
> --^ 0x00254f84--^ 0x00254ec4--^ 0x00135648--^ 0x00135854--^ 0x001358ac
> --^ 0x001321f4--^ 0x0012aa4c--^ 0x0010b08c--^ 0x001039e8--^ 0x000f502c
> --^ 0x000fd6cc--^ 0x0001360c--^ 0x0025f628--^ 0x00262f64--^ 0x0025dd08
> *** FATAL ***
> next PC or address of fault = 0x0025d240
> R0 = 0x0025d270 R1 = 0x004945e8 R2 = 0x00000000 R3 = 0x002bdd8c
> R4 = 0x00000000 R5 = 0x002784e8 R6 = 0x00494578 R7 = 0x002784ea
> R8 = 0x002784e9 R9 = 0xa5a5a5a5 R10 = 0x800003fd R11 = 0x00000000
> R12 = 0x40442202 R13 = 0x003006c0 R14 = 0x004946a8 R15 = 0x00000000
> R24 = 0x00336560 R25 = 0x00000000 R26 = 0x002a41b0 R27 = 0x002784e8
> R28 = 0xcccccccd R29 = 0x002bdd8c R30 = 0x00494a10 R31 = 0x00000010
> CR = 0x40442808
> CTR = 0x00254fe8
> XER = 0x20000000
> LR = 0x0025d270
> DAR = 0xa5a5a5a9
> Stack Trace:
> IP: 0x0025d240, LR: 0x0025d270
> --^ 0x00254f64--^ 0x00135648--^ 0x00135854--^ 0x002662f0--^ 0x0025de68
> --^ 0x40842402--^ 0x00254f84--^ 0x00254ec4--^ 0x00135648--^ 0x00135854
> --^ 0x001358ac--^ 0x001321f4--^ 0x0012aa4c--^ 0x0010b08c--^ 0x001039e8
> --^ 0x000f502c--^ 0x000fd6cc--^ 0x0001360c--^ 0x0025f628--^ 0x00262f64
> --^ 0x0025dd08
> ADDR2LINE
> line to Analyzed 0x00254f84 0x00254ec4 0x00135648 0x00135854 0x001358ac
> ADDR: 0x00254f84 -> bsp_reset
> ADDR: 0x00254ec4 -> bsp_fatal_extension
> ADDR: 0x00135648 -> _User_extensions_Iterate
> ADDR: 0x00135854 -> _Terminate
> ADDR: 0x001358ac -> _Workspace_Handler_initialization
> line to Analyzed 0x001321f4 0x0012aa4c 0x0010b08c 0x001039e8 0x000f502c
> ADDR: 0x001321f4 -> _Thread_Dispatch_enable
> ADDR: 0x0012aa4c -> _POSIX_Get_error
> ADDR: 0x0010b08c -> epicsEventWait
> ADDR: 0x001039e8 -> epicsEventMustWait
> ADDR: 0x000f502c -> errlogFlush
> line to Analyzed 0x000fd6cc 0x0001360c 0x0025f628 0x00262f64 0x0025dd08
> ADDR: 0x000fd6cc -> cantProceed
> ADDR: 0x0001360c -> pmacMbxReceiptISR
> ADDR: 0x0025f628 -> universeVMEISR
> ADDR: 0x00262f64 -> bsp_interrupt_handler_dispatch
> ADDR: 0x0025dd08 -> wrap_change_msr_done_std
> line to Analyzed
> line to Analyzed 0x00254f64 0x00135648 0x00135854 0x002662f0 0x0025de68
> ADDR: 0x00254f64 -> rtems_exception_frame_print
> /gem_base/targetOS/RTEMS/rtems/kernel/rtems/cpukit/include/rtems/fatal.h:60
> Regards,
- Re: fatal code: 30 (INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL) Joel Sherrill via Tech-talk
- fatal code: 30 (INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL) Francisco Ramos via Tech-talk
Re: fatal code: 30 (INTERNAL_ERROR_BAD_THREAD_DISPATCH_DISABLE_LEVEL) Heinz Junkes via Tech-talk
<2022>
2025
2026
<2022>
2025
2026
