1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: FLNK doesn't process
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Tue, 18 Jan 2022 21:45:13 +0100
Hi Matt,
On Tue, 18 Jan 2022 at 16:38, Pearson, Matthew via Tech-talk <[email protected]> wrote:
Another way to answer the original question, at the expense of adding an additional record, is to do this:
The advantage of the above is that you can use put_callback to set the setpoint and immediately check the readback to see if the value was accepted, like:
bash> caput -c setpoint 10.0
bash> caget readback
which doesn’t work if you have a CA link involved.
Careful.
Your database is perfectly fine. But your Stream record 'setpoint' processes asynchronously, and in that case put_callback returns after the first phase of record processing, i.e. after the request to write the value has been issued. If your device is slow (and you're typing fast) you can execute the 'caget' and fetch the old value before the 'readback' record has been processed. (Add a wait command inside the write protocol to play with this.)
Things are different when you set up a camonitor for 'readback'. In that case, the 'setpoint's FLNK processes the 'readback' record, and after the second phase of that processing, the monitor update will be sent.
Asynchronously processing records are tricky. FLNK and monitors (i.e., CP input links) are your friends, as they fire after the second phase.
The get, put and put_callback operations return after the first phase and may lead to less robust (timing/load dependent) operation.
Cheers,
~Ralph
Re: [EXTERNAL] Re: FLNK doesn't process Ralph Lange via Tech-talk
FLNK doesn't process Randall Cayford via Tech-talk
Re: FLNK doesn't process Hu, Yong via Tech-talk
Re: FLNK doesn't process Randall Cayford via Tech-talk
Re: FLNK doesn't process William Kirstaedter via Tech-talk
RE: [EXTERNAL] Re: FLNK doesn't process Pearson, Matthew via Tech-talk
Prev: RE: [EXTERNAL] Re: FLNK doesn't process Pearson, Matthew via Tech-talk
Next: Re: [EXTERNAL] Re: FLNK doesn't process Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
