1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: FLNK doesn't process
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Wed, 19 Jan 2022 10:28:23 +0100
Erratum
On Tue, 18 Jan 2022 at 21:45, Ralph Lange <[email protected]> wrote:
Careful.
Your database is perfectly fine. But your Stream record 'setpoint' processes asynchronously, and in that case put_callback returns after the first phase of record processing, i.e. after the request to write the value has been issued.
That's not true. put_callback returns after the second phase processing and is used absolutely fine in this context. I got confused.
Sounds like EPICS is better than I thought. Thanks to Matt and Andrew for pointing this out.
Cheers,
~Ralph
FLNK doesn't process Randall Cayford via Tech-talk
Re: FLNK doesn't process Hu, Yong via Tech-talk
Re: FLNK doesn't process Randall Cayford via Tech-talk
Re: FLNK doesn't process William Kirstaedter via Tech-talk
Re: FLNK doesn't process Ralph Lange via Tech-talk
RE: [EXTERNAL] Re: FLNK doesn't process Pearson, Matthew via Tech-talk
Re: [EXTERNAL] Re: FLNK doesn't process Ralph Lange via Tech-talk
Prev: Re: [EXTERNAL] Re: FLNK doesn't process Ralph Lange via Tech-talk
Next: Returning to the EPICS community as a freelancer Ian Gillingham via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: SmarPod with EPICS Bahareh Shidrang via Tech-talk
