Ø
I surmise that, when you say “hardware interrupts”, you refer to the interrupt sources that a driver can enable or disable on the device, while with “software interrupts”, you refer to the mechanism by which the interrupts are
propagated from the driver to the EPICS records, regardless of whether they originate in hardware or some software event in the driver. Correct?
That is correct. A common example of a software event is the driver polling the hardware, and doing the callbacks to process the EPICS records when the value changes.
It appears, then, that the `asynUInt32Digital' interface has two distinct parts:
• `registerInterruptUser()' and `cancelInterruptUser()' deal with “software
interrupts” and allow EPICS device support layer to subscribe to events from
the driver;
• `{set,get,clear}Interrupt()' tell the driver to enable or disable particular
hardware interrupts. The driver needs to override the default implementation
of this interface to use it, like `ipUnidig' does.
That is correct.
Ø
In any case, as I had pointed out, asyn’s EPICS device support layer does not have any calls to `{set,get,clear}Interrupt()'. So who does `ipUnidig' implement this for? Some non-EPICS user?
That is an excellent point. In fact, there is currently no way to call the setInterruptUInt32Digital method in the IPUnidig driver from EPICS records. The configuration of the hardware interrupts is done in the constructor using the
risingMask and fallingMask variables passed to initIPUnidig from the startup script, and there is currently no way to change them at run-time.
If there is a need to configure the interrupts for that then there are 2 possible solutions:
devAsynUInt32Digital.c could be changed to support calling the setInterrupt and clearInterrupt methods in the asynUInt32Digital interface. One would need to establish a convention of the value of the drvUser field in the record link
field that means this is an interrupt mask, not a data value.
A simpler solution for the IpUnidig would be to extend the drvUser fields it supports. Currently these are:
#define digitalInputString "DIGITAL_INPUT"
#define digitalOutputString "DIGITAL_OUTPUT"
#define DACOutputString "DAC_OUTPUT"
One could add:
#define risingMaskString "RISING_MASK"
#define fallingMaskString "FALLING_MASK"
and add these to the parameter library.
The driver’s writeUInt32Digital method would then check the pasynUser->reason, and if it is one of these values then it would call the setInterruptUInt32Digital method internally.
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Jure Varlec via Tech-talk
Sent: Thursday, January 27, 2022 1:48 AM
To: tech-talk at aps.anl.gov
Subject: Re: Use of asyn's setInterruptUInt32Digital in EPICS device support
Hello Mark,
Thanks for the explanation, it helps a lot; I knew I was confused, of course, but not exactly where the issue was. I often have problems with nomenclature as various terms used in asyn are very context-dependent; in particular, I think
I lack some background information to understand the distinction between hardware and software interrupts you make in this context. I surmise that, when you say “hardware interrupts”, you refer to the interrupt sources that a driver can enable or disable on
the device, while with “software interrupts”, you refer to the mechanism by which the interrupts are propagated from the driver to the EPICS records, regardless of whether they originate in hardware or some software event in the driver. Correct?
the driver;
But I may have misunderstood the distinction :)
Jure
Mark Rivers <rivers at cars.uchicago.edu> writes:
> Hi Jure,
>> I’m looking at `asynPortDriver::setInterruptUInt32Digital()’ which is
>> documented to be “called when asyn clients call
> `pasynUInt32Digital->setInterrupt()’”.
>> However, EPICS device support (`devAsynUInt32Digital.c’) does not contain such a call.
> You are looking in the wrong place for that call. That call is not
> part of device support, it is part of the asynUInt32Digital interface, and so is present here:
> <https://github.com/epics-modules/asyn/blob/a2f59505766f5a19af1afb325f
> c84b3a1d77552f/asyn/interfaces/asynUInt32Digital.h#L44>
> pasynUInt32Digital->setInterrupt() is used to configure the driver to control which bits will generate interrupts.
> It is implemented in the IPUnidig driver, for example:
> <https://github.com/epics-modules/ipUnidig/blob/990c5920e6a50f17b164db
> 0477ccfdc28df97442/ipUnidigApp/src/drvIpUnidig.cpp#L543>
>> I’d expect, from the driver point of view, to be able to use
>> `asynPortDriver::getInterruptUInt32Digital()’ to learn
> which bits records are interested in.
> No, it is the reverse. Device support calls
> getInterruptUInt32Digital() to learn which bits the hardware has configured to generate interrupts.
>> • On read or write, `asynUInt32Digital’ passes the mask and the value to/from in the way appropriate for the device.
> Yes, that is true.
>> For interrupts, `asynPortDriver’ will consider the mask given to
>> `setUIntDigitalParam()’ and figure out which `IO
> Intr’ records to process based on both the mask and which bits in the value have changed.
> Yes, that is true. But this has nothing to do with driver/hardware
> interrupts, which is what setInterruptUInt32Digital() is designed to control.
>> If the last point is true, then I guess
>> `asynPortDriver::setInterruptUInt32Digital()’ really doesn’t seem
>> useful for
> EPICS. I hope now you see why I’m wondering what it’s about
> You are mixing up software interrupts which are handled using
> callbacks for records with SCAN=I/O Intr with driver/hardware
> interrupts. They are completely separate. asynPortDriver::setInterruptUInt32Digital() only controls driver/hardware interrupts, which is why it is not used in many places.
> Mark
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Jure
> Varlec via Tech-talk <tech-talk at aps.anl.gov>
> Sent: Wednesday, January 26, 2022 2:32 AM
> To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
> Subject: Use of asyn’s setInterruptUInt32Digital in EPICS device
> support
> Dear all,
> documented to be “called when asyn clients call `pasynUInt32Digital->setInterrupt()’”.
> It’s not clear to me how this interface is meant to be used. I’d
> `asynPortDriver::getInterruptUInt32Digital()’ to learn which bits
> records are interested in. However, this does not work with EPICS, I
> don’t see how it could be set to logical-or of masks for all `IO Intr’
> records, and I don’t see a use case for anything else. I don’t have a
> use case myself; I’m just wondering how the interface works and what
> it is meant for, presuming that it was implemented with some purpose in mind.
> Actually, I feel a bit unsure as to how the mask in the UInt32Digital
> interface really works. The documentation appears to be quite sparse
> on this topic. My understanding is the following:
> • `asynInt32’ deals with the mask in EPICS device support layer support while
> `asynUInt32Digital’ delegates that to the driver.
> the driver unmodified. It’s up to the driver to apply the mask to the value
> • For interrupts, `asynPortDriver’ will consider the mask given to
> `setUIntDigitalParam()’ and figure out which `IO Intr’ records to process
> useful for EPICS. I hope now you see why I’m wondering what it’s about
> Best regards,
> Jure Varlec
> Senior Software Developer
> Cosylab d.d.
> www.cosylab.com
