1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Phoebus-olog integration
From: Juan F. Esteban Müller via Tech-talk <[email protected]>
To: "Larregui, Julian" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 28 Jan 2022 12:18:22 +0000
Hello Julian,
The logbook factory setting should be “olog-es”. Apart from that, check the url, you might need to use “org.phoebus.olog.es.api/olog_url=http://localhost:8080/Olog”.
Cheers,
Juan
From: Tech-talk <[email protected]> on behalf of "Larregui, Julian via Tech-talk" <[email protected]>
Reply-To: "Larregui, Julian" <[email protected]>
Date: Thursday, 27 January 2022 at 23:58
Subject: Phoebus-olog integration
Hello,
I've downloaded the package from https://github.com/Olog/phoebus-olog.
Gone through the installation instructions and set up both elasticsearch, mongodb, install for olog, and able to see the connection status on my web browser.
Afterwards I checked to make sure I am able to create logbooks, and log entry which was successful.
My issue is now trying to get it working on phoebus so I can create logs for my displays.
I thought adding the following to the settins.ini would have been enough, but it isn't:
org.phoebus.logbook/logbook_factory=olog
org.phoebus.olog.api/olog_url=localhost:8086/Olog
org.phoebus.olog.api/username=admin
org.phoebus.olog.api/password=1234
I get an error at startup:
WARNING [org.phoebus.logbook] Cannot locate logbook factory 'olog'
I'm not sure what else I am missing or mistake I am made. I would be grateful for any advise on how to proceed.
Thank you,
Julian
Re: Phoebus-olog integration Larregui, Julian via Tech-talk
Prev: Re: [EXTERNAL] Phoebus - image on Boolean-Button Mogamad Amien Crombie via Tech-talk
Next: RE: Adding a second output array to an areaDetector IOC Iain Marcuson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Phoebus-olog integration Larregui, Julian via Tech-talk
Next: Re: Phoebus-olog integration Larregui, Julian via Tech-talk
