1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Phoebus-olog integration
From: "Larregui, Julian via Tech-talk" <[email protected]>
Date: Thu, 27 Jan 2022 22:58:28 +0000
Hello,
I've downloaded the package from https://github.com/Olog/phoebus-olog.
Gone through the installation instructions and set up both elasticsearch, mongodb, install for olog, and able to see the connection status on my web browser.
Afterwards I checked to make sure I am able to create logbooks, and log entry which was successful.
My issue is now trying to get it working on phoebus so I can create logs for my displays.
I thought adding the following to the settins.ini would have been enough, but it isn't:
org.phoebus.logbook/logbook_factory=olog
org.phoebus.olog.api/olog_url=localhost:8086/Olog
org.phoebus.olog.api/username=admin
org.phoebus.olog.api/password=1234
I get an error at startup:
WARNING [org.phoebus.logbook] Cannot locate logbook factory 'olog'
I'm not sure what else I am missing or mistake I am made. I would be grateful for any advise on how to proceed.
Thank you,
Julian
Re: Phoebus-olog integration Juan F. Esteban Müller via Tech-talk
Prev: Re: ADVimba memory leak ? Mark Rivers via Tech-talk
Next: motor record field assignment problem 高振华 via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Job opportunities at Diamond: Software Systems Engineers and so much more Pedersen, Ulrik (DLSLtd, RAL, LSCI) via Tech-talk
Next: Re: Phoebus-olog integration Juan F. Esteban Müller via Tech-talk
