1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: motor record field assignment problem
To: "mark rivers" <[email protected]>
Cc: [email protected]
Date: Fri, 28 Jan 2022 11:49:49 +0800 (GMT+08:00)
Hello Mark,
I am learning stepper motor control and have encountered some problems.
1. I don't know how to fill in the values of DTYP and OUT fields in motor records.
For a certain type of stepper motor controller how to know its corresponding DTYP value and OUT or INP field assignment format?  I can't find the assignment format description in the motor example and documentation, do I have to look it up in the source code?
2. the content of the motordevicedriver. HTML file is not completely displayed, and only this sentence is displayed:
 asynMotorAxis base class
The asynMotorAxis base class defines the following methods:”
Where can I download a full version?
3. By which field is the SSCAN record connected to the motor record?
  • For example, the motor record of the OMS VME58 is shown below
Thank you!
Best regards,
Gao Zhenhua
BSRF(Beijing Synchrotron Radiation Facility)
Email:[email protected]
Re: motor record field assignment problem Kevin Peterson via Tech-talk
Prev: Phoebus-olog integration Larregui, Julian via Tech-talk
Next: Re: [EXTERNAL] Phoebus - image on Boolean-Button Mogamad Amien Crombie via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Phoebus-olog integration Larregui, Julian via Tech-talk
Next: Re: motor record field assignment problem Kevin Peterson via Tech-talk
