Subject: |
Re: Phoebus-olog integration |
"Larregui, Julian via Tech-talk" <[email protected]> |
To: |
Date: |
Tue, 1 Feb 2022 18:40:31 +0000 |
Hello,
Thank you for the assistance, that was the issue at hand. I went ahead and got another build of phoebus which worked. Log creation is successful. The only odd thing is the log entry table. When searching for logs I get an error reporting no entry is found.
Any way to change that?
Thank you,
> WARNING [org.phoebus.ui.application.PhoebusApplication] Undefined logbook factory olog-es
Different sites use different logbooks.
Did you build CS-Studio with support for the OLog? Or did you use a pre-built version from a site that uses the OLog?
In that case, the ..../lib folder of the product should contain a file app-logbook-olog-client-*.jar
If you downloaded a pre-built binary from the SNS, where you don't use the OLog, that won't be there, and that would explain why the olog-es is unknown.
-Kay
- Phoebus-olog integration Larregui, Julian via Tech-talk
- Re: Phoebus-olog integration Juan F. Esteban Müller via Tech-talk
- Re: Phoebus-olog integration Larregui, Julian via Tech-talk
- Re: Phoebus-olog integration Kasemir, Kay via Tech-talk
A Tribute to our Colleague Marty Kraimer Rolf Keitel via Tech-talk
Conda package for MEDM Thomas, Patrick via Tech-talk
<2022>
2025
2026
motor record field assignment problem 高振华 via Tech-talk
<2022>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
