1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Phoebus-olog integration
From: "Kasemir, Kay via Tech-talk" <tech-talk at aps.anl.gov>
To: "Larregui, Julian via Tech-talk" <tech-talk at aps.anl.gov>, "Larregui, Julian" <larregui1 at llnl.gov>
Date: Mon, 31 Jan 2022 21:35:58 +0000
> WARNING [org.phoebus.ui.application.PhoebusApplication] Undefined logbook factory olog-es
Different sites use different logbooks.
Did you build CS-Studio with support for the OLog? Or did you use a pre-built version from a site that uses the OLog?
In that case, the ..../lib folder of the product should contain a file app-logbook-olog-client-*.jar
If you downloaded a pre-built binary from the SNS, where you don't use the OLog, that won't be there, and that would explain why the olog-es is unknown.
-Kay
Re: Phoebus-olog integration Larregui, Julian via Tech-talk
Re: Phoebus-olog integration Juan F. Esteban Müller via Tech-talk
Prev: Re: Phoebus-olog integration Larregui, Julian via Tech-talk
Next: Re: Questions from the Static Database Access chapter of the Application Developer's Guide Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: Phoebus-olog integration Larregui, Julian via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
