1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Channel Finder Error
From: "Larregui, Julian via Tech-talk" <[email protected]>
Date: Thu, 3 Feb 2022 18:44:55 +0000
Hello,
Being trying to get the ChannelFinder module to work, but ran into some issues.
After installing the ChannelFinder, I am verifying that everything is running correctly.
The "curl http://localhost:8080/ChannelFinder" works just fine.
the  "curl http://localhost:8080/ChannelFinder/resources/tags"  runs an error which states:
Elasticsearch exception [type=search_phase_execution_exception, reason=all shards failed]","path":"/ChannelFinder/resources/tags"
and
type=illegal_argument_exception, reason=Fielddata is disabled on text fields by default. Set fielddata=true on [name] in order to load fielddata in memory by uninverting the inverted index.
Nothing else works aside from that. Is there any possible solution to this?
Thank you,
Prev: Re: Questions from the Static Database Access chapter of the Application Developer's Guide Andrew Johnson via Tech-talk
Next: Re: Questions from the Static Database Access chapter of the Application Developer's Guide Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: .RE: Configuring serial communication with Lakeshore 331 via Moxa (Mark Rivers) Kevin Peterson via Tech-talk
Next: Creating a database record Dudley, David via Tech-talk
