Is it possible from with a device driver that before iocInit (or during some part of it) to programmatically build a database record for use in EPICS?
I know of a driver that does that, yes. In the initialization of the driver (started by calls from the startup script) they detect the hardware and create a matching DB file in '/tmp', then load that file. Works fine.
I don't like that for a production system for multiple reasons. Having no or little control over which records an IOC loads.... Broken cards that would just disappear from the name space with no trace.... But I see the advantage for plug-and-play lab use.
If you don't hard code the records into the driver code, but maybe blow up from templates that are part of your application, you would give the user at least some control.
Cheers, ~Ralph
- Re: [EXTERNAL] Creating a database record Vodopivec, Klemen via Tech-talk
- RE: Creating a database record Dudley, David via Tech-talk
- Creating a database record Dudley, David via Tech-talk
Re: [EXTERNAL] A Tribute to our Colleague Marty Kraimer Tang, Johnny via Tech-talk
Potentiostat EPICS driver (EC301 / SP-300) Nilson Pereira via Tech-talk
<2022>
2025
Re: Creating a database record Michael Davidsaver via Tech-talk
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
