Hi Mark,
I'm running on windows because I'm building a control system in LabVIEW, and all the other elements in the system are setup on windows.
Writing a driver with the Pylon SDK seems like a promising solution. Would you be willing to put one together? Or if not, how would you recommend I start that process?
Bryan
Sent: Wednesday, February 9, 2022 11:38 AM
To: Sullivan,Bryan <Bryan.Sullivan at colostate.edu>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: Connecting Basler camera with areaDetector on Windows
** Caution: EXTERNAL Sender **
Hi Bryan,
The Windows support in aravis is very new. The Windows GigEVision support was added less than a year ago, and I was not aware of it. ADAravis and aravisGigE currently
only work on Linux.
The aravis documentation does explain how to install aravis on Windows using msys2 (gcc) or using MSVC. Once it is installed it should be possible change ADAravis to build
with it on Windows, but it will definitely require work.
If there is not a strong reason to use Windows I would suggest using Linux instead. It should just work out of the box.
Alternatively, the Basler Pylon SDK works on both Linux and Windows. A driver using that SDK could be written, as I have done with ADSpinnaker and ADVimba for other vendor
SDKs.
On Behalf Of Sullivan,Bryan via Tech-talk
Sent: Wednesday, February 9, 2022 11:16 AM
To: tech-talk at aps.anl.gov
Subject: Connecting Basler camera with areaDetector on Windows
I am trying to connect a Basler camera with areaDetector. I saw in a previous tech-talk (https://epics.anl.gov/tech-talk/2020/msg00388.php)
that the aravisGigE and ADAravis modules should work with basler. I would prefer to use ADAravis since it is newer and better optimized, but when reading the documentation, I saw that ADAravis explicitly states that it cannot be used on windows because the
underlying library aravis does not support it (https://areadetector.github.io/master/ADAravis/ADAravis.html)
but in the aravis documentation it gives instruction on how to install on windows (https://github.com/AravisProject/aravis).
Then with aravidGigE the documentation says it works on windows but then only gives instruction on how to install on lunix.
- Can ADAravis be used on windows?
- Given a set of instructions for installing on lunix how can I adapt those to install on windows?
- RE: Connecting Basler camera with areaDetector on Windows Mark Rivers via Tech-talk
- Connecting Basler camera with areaDetector on Windows Sullivan,Bryan via Tech-talk
<2022>
<2022>
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
