Subject: |
error building asyn4-38 : cross_compiler_target_archs=linux-arm |
"chaker.maazouzi--- via Tech-talk" <[email protected]> |
To: |
Date: |
Wed, 16 Feb 2022 18:14:52 +0100 |
Hi
Sorry, but maybe my question will be a duplicate. but I can't find a
solution to my compilation error. My project is to integrate a redpitaya
module into my setup, I am trying to compile asyn4-38;
I using base3.16.2 :
I set in $(EPICS_BASE)/configure/CONFIG_SITE file
CROSS_COMPILER_TARGET_ARCHS=linux-arm
CROSS_COMPILER_HOST_ARCHS=linux-x86_64
In file $(EPICS_BASE) configure/os/CONFIG_SITE.linux-x86.linux-arm (called
in configure/os/CONFIG_SITE.linux-x86_64.linux-arm) I set
GNU_TARGET = arm-linux-gnueabihf
GNU_DIR=/mnt/hgfs/DDhote/linux_linaro/gcc-linaro-6.3.1-2017.02-x86_64_arm-li
nux-gnueabihf
I add also after consulting the tech-talk website :
SHARED_LIBRARIES=YES
STATIC_BUILD=NO
compilation and building of the base is done without problem.
then i try to install asyn4-38 :
first I set in $(SUPPORT)/asyn4-38/configure/CONFIG_SITE file
After some errors(vxi11core_drv, rpcgen) I install libtirpc-devel.x86_64
and rpcgen.x86_64 on my host
And uncomment TIRPC=YES in the same CONFIG_STE file
despite these actions I still get the error : ....
cannot find -ltirpc
[root@localhost support]# make
make -C ./configure install
make[1] : on entre dans le répertoire « /home/epicsmgr/support/configure »
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
T_A=linux-x86_64 install
make[2] : on entre dans le répertoire «
/home/epicsmgr/support/configure/O.linux-x86_64 »
perl -CSD /home/epicsmgr/base-3.16.2/bin/linux-x86_64/convertRelease.pl
checkRelease
make[2] : on quitte le répertoire «
make -C O.linux-arm -f ../Makefile TOP=../.. \
T_A=linux-arm install
/home/epicsmgr/support/configure/O.linux-arm »
checkRelease
make[1] : on quitte le répertoire « /home/epicsmgr/support/configure »
make -C ./asyn install
make[1] : on entre dans le répertoire « /home/epicsmgr/support/asyn4-38 »
/home/epicsmgr/support/asyn4-38/configure »
make[3] : on entre dans le répertoire «
/home/epicsmgr/support/asyn4-38/configure/O.linux-x86_64 »
checkRelease
make[3] : on quitte le répertoire «
/home/epicsmgr/support/asyn4-38/configure/O.linux-arm »
checkRelease
make -C ./makeSupport install
/home/epicsmgr/support/asyn4-38/makeSupport »
/home/epicsmgr/support/asyn4-38/makeSupport/O.linux-x86_64 »
make[3]: rien à faire pour « install ».
/home/epicsmgr/support/asyn4-38/makeSupport/O.linux-arm »
make[2] : on entre dans le répertoire « /home/epicsmgr/support/asyn4-38/asyn
/home/epicsmgr/support/asyn4-38/asyn/O.linux-x86_64 »
/home/epicsmgr/support/asyn4-38/asyn/O.linux-arm »
/mnt/hgfs/DDhote/linux_linaro/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gnue
abihf/bin/arm-linux-gnueabihf-g++ -o libasyn.so -shared -fPIC
-L/home/epicsmgr/support/asyn4-38/lib/linux-arm
-L/home/epicsmgr/base-3.16.2/lib/linux-arm
-Wl,-rpath,/home/epicsmgr/support/asyn4-38/lib/linux-arm
-Wl,-rpath,/home/epicsmgr/base-3.16.2/lib/linux-arm -rdynamic
-L/mnt/hgfs/DDhote/linux_linaro/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gn
ueabihf/arm-linux-gnueabihf/lib asynManager.o
epicsInterruptibleSyscall.o asynGpib.o drvAsynSerialPort.o drvAsynIPPort.o
drvAsynIPServerPort.o asynInt32Base.o asynInt32SyncIO.o asynInt64Base.o
asynInt64SyncIO.o asynInt8ArrayBase.o asynInt8ArraySyncIO.o
asynInt16ArrayBase.o asynInt16ArraySyncIO.o asynInt32ArrayBase.o
asynInt32ArraySyncIO.o asynInt64ArrayBase.o asynInt64ArraySyncIO.o
asynUInt32DigitalBase.o asynUInt32DigitalSyncIO.o asynFloat64Base.o
asynFloat64SyncIO.o asynFloat32ArrayBase.o asynFloat32ArraySyncIO.o
asynFloat64ArrayBase.o asynFloat64ArraySyncIO.o asynOctetBase.o
asynOctetSyncIO.o asynGenericPointerBase.o asynGenericPointerSyncIO.o
asynEnumBase.o asynEnumSyncIO.o asynCommonSyncIO.o asynOptionSyncIO.o
asynStandardInterfacesBase.o asynShellCommands.o asynInterposeCom.o
asynInterposeEos.o asynInterposeFlush.o asynInterposeDelay.o
asynInterposeEcho.o ParamListInvalidIndex.o ParamListParamNotFound.o
ParamValNotDefined.o ParamValStringSizeRequestTooBig.o ParamValWrongType.o
ParamValValueNotChanged.o paramVal.o asynPortDriver.o asynPortClient.o
devAsynOctet.o asynEpicsUtils.o devAsynInt32.o devAsynInt8Array.o
devAsynInt16Array.o devAsynInt32Array.o devAsynInt32TimeSeries.o
devAsynUInt32Digital.o devAsynFloat64.o devAsynFloat32Array.o
devAsynFloat64Array.o devAsynFloat64TimeSeries.o devAsynInt64Array.o
devAsynInt64TimeSeries.o devAsynInt64.o asynRecord.o drvAsyn.o
vxi11core_xdr.o drvVxi11.o E5810Reboot.o E2050Reboot.o TDS3000Reboot.o
devCommonGpib.o devSupportGpib.o boSRQonOff.o -ldbRecStd -ldbCore -lca
-lCom -ltirpc -lpthread -lm -lrt -ldl -lgcc
abihf/bin/../lib/gcc/arm-linux-gnueabihf/6.3.1/../../../../arm-linux-gnueabi
hf/bin/ld: cannot find -ltirpc
collect2: error: ld returned 1 exit status
make[3]: *** [/home/epicsmgr/base-3.16.2/configure/RULES_BUILD:292:
libasyn.so] Error 1
make[2]: *** [/home/epicsmgr/base-3.16.2/configure/RULES_ARCHS:58:
install.linux-arm] Error 2
make[2] : on quitte le répertoire « /home/epicsmgr/support/asyn4-38/asyn »
make[1]: *** [/home/epicsmgr/base-3.16.2/configure/RULES_DIRS:84:
asyn.install] Error 2
make[1] : on quitte le répertoire « /home/epicsmgr/support/asyn4-38 »
make: *** [/home/epicsmgr/base-3.16.2/configure/RULES_DIRS:84: asyn.install]
Error 2
Thank you very much for your attention to my problem.
Regards
Chaker Maazouzi
- RE: error building asyn4-38 : cross_compiler_target_archs=linux-arm Mark Rivers via Tech-talk
Re: Creating a database record Michael Davidsaver via Tech-talk
<2022>
2025
2026
Re: [EXTERNAL] Pheobus Alarm-System - Handling varying locations for associated displays Kasemir, Kay via Tech-talk
<2022>
2025
2026
