1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: error building asyn4-38 : cross_compiler_target_archs=linux-arm
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: "chaker.maazouzi at iphc.cnrs.fr" <chaker.maazouzi at iphc.cnrs.fr>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 16 Feb 2022 18:22:18 +0000
Hi Chaker,
Your error is:
/mnt/hgfs/DDhote/linux_linaro/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gnueabihf/bin/../lib/gcc/arm-linux-gnueabihf/6.3.1/../../../../arm-linux-gnueabihf/bin/ld: cannot find -ltirpc
It is searching for libtirpc as a SYS_LIBS because of this in asyn/asyn/Makefile
ifeq ($(TIRPC),YES)
  USR_INCLUDES_Linux += -I/usr/include/tirpc
  asyn_SYS_LIBS_Linux += tirpc
endif
You said the following:
Ø   I install libtirpc-devel.x86_64
But that is not what you need.  That installed the x86_64 version of libtirpc.so, not the ARM version. You need to install the ARM version of tirpc.
You may need to explicitly add tirpc_DIR = path_to_that_directory to a new file you create,  CONFIG_SITE.local. linux-x86_64.linux-arm.
-----Original Message-----
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of chaker.maazouzi--- via Tech-talk
Sent: Wednesday, February 16, 2022 11:15 AM
To: tech-talk at aps.anl.gov
Subject: error building asyn4-38 : cross_compiler_target_archs=linux-arm
Hi
Sorry, but maybe my question will be a duplicate. but I can't find a solution to my compilation error. My project is to integrate a redpitaya module into my setup, I am trying to compile asyn4-38; I using base3.16.2 :
I set in $(EPICS_BASE)/configure/CONFIG_SITE file
          CROSS_COMPILER_TARGET_ARCHS=linux-arm
          CROSS_COMPILER_HOST_ARCHS=linux-x86_64
In file $(EPICS_BASE) configure/os/CONFIG_SITE.linux-x86.linux-arm  (called in configure/os/CONFIG_SITE.linux-x86_64.linux-arm)  I set GNU_TARGET = arm-linux-gnueabihf GNU_DIR=/mnt/hgfs/DDhote/linux_linaro/gcc-linaro-6.3.1-2017.02-x86_64_arm-li
nux-gnueabihf
I add also after consulting the tech-talk website :
SHARED_LIBRARIES=YES
STATIC_BUILD=NO
compilation and building of the base is done without problem.
then i try to install asyn4-38 :
first I set in $(SUPPORT)/asyn4-38/configure/CONFIG_SITE file
After some errors(vxi11core_drv, rpcgen)  I install libtirpc-devel.x86_64 and rpcgen.x86_64 on my host And uncomment TIRPC=YES in the same CONFIG_STE file
despite these actions I still get the error :                          ....
cannot find -ltirpc
[root@localhost support]# make
make -C ./configure install
make[1] : on entre dans le répertoire « /home/epicsmgr/support/configure » make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2] : on entre dans le répertoire «
/home/epicsmgr/support/configure/O.linux-x86_64 » perl -CSD /home/epicsmgr/base-3.16.2/bin/linux-x86_64/convertRelease.pl
checkRelease
make[2] : on quitte le répertoire «
/home/epicsmgr/support/configure/O.linux-x86_64 » make -C O.linux-arm -f ../Makefile TOP=../.. \
    T_A=linux-arm install
/home/epicsmgr/support/configure/O.linux-arm » perl -CSD /home/epicsmgr/base-3.16.2/bin/linux-x86_64/convertRelease.pl
checkRelease
/home/epicsmgr/support/configure/O.linux-arm » make[1] : on quitte le répertoire « /home/epicsmgr/support/configure » make -C ./asyn install make[1] : on entre dans le répertoire « /home/epicsmgr/support/asyn4-38 » make -C ./configure install make[2] : on entre dans le répertoire « /home/epicsmgr/support/asyn4-38/configure » make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
make[3] : on entre dans le répertoire «
/home/epicsmgr/support/asyn4-38/configure/O.linux-x86_64 » perl -CSD /home/epicsmgr/base-3.16.2/bin/linux-x86_64/convertRelease.pl
checkRelease
make[3] : on quitte le répertoire «
/home/epicsmgr/support/asyn4-38/configure/O.linux-x86_64 » make -C O.linux-arm -f ../Makefile TOP=../.. \
/home/epicsmgr/support/asyn4-38/configure/O.linux-arm » perl -CSD /home/epicsmgr/base-3.16.2/bin/linux-x86_64/convertRelease.pl
checkRelease
/home/epicsmgr/support/asyn4-38/configure/O.linux-arm » make[2] : on quitte le répertoire « /home/epicsmgr/support/asyn4-38/configure » make -C ./makeSupport install make[2] : on entre dans le répertoire « /home/epicsmgr/support/asyn4-38/makeSupport » make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
/home/epicsmgr/support/asyn4-38/makeSupport/O.linux-x86_64 »
make[3]: rien à faire pour « install ».
/home/epicsmgr/support/asyn4-38/makeSupport/O.linux-x86_64 » make -C O.linux-arm -f ../Makefile TOP=../.. \
/home/epicsmgr/support/asyn4-38/makeSupport/O.linux-arm »
/home/epicsmgr/support/asyn4-38/makeSupport/O.linux-arm » make[2] : on quitte le répertoire « /home/epicsmgr/support/asyn4-38/makeSupport » make -C ./asyn install make[2] : on entre dans le répertoire « /home/epicsmgr/support/asyn4-38/asyn
/home/epicsmgr/support/asyn4-38/asyn/O.linux-x86_64 »
/home/epicsmgr/support/asyn4-38/asyn/O.linux-x86_64 » make -C O.linux-arm -f ../Makefile TOP=../.. \
/home/epicsmgr/support/asyn4-38/asyn/O.linux-arm » /mnt/hgfs/DDhote/linux_linaro/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gnue
abihf/bin/arm-linux-gnueabihf-g++ -o libasyn.so -shared -fPIC -L/home/epicsmgr/support/asyn4-38/lib/linux-arm
-L/home/epicsmgr/base-3.16.2/lib/linux-arm
-Wl,-rpath,/home/epicsmgr/support/asyn4-38/lib/linux-arm
-Wl,-rpath,/home/epicsmgr/base-3.16.2/lib/linux-arm            -rdynamic
-L/mnt/hgfs/DDhote/linux_linaro/gcc-linaro-6.3.1-2017.02-x86_64_arm-linux-gn
ueabihf/arm-linux-gnueabihf/lib            asynManager.o
epicsInterruptibleSyscall.o asynGpib.o drvAsynSerialPort.o drvAsynIPPort.o drvAsynIPServerPort.o asynInt32Base.o asynInt32SyncIO.o asynInt64Base.o asynInt64SyncIO.o asynInt8ArrayBase.o asynInt8ArraySyncIO.o asynInt16ArrayBase.o asynInt16ArraySyncIO.o asynInt32ArrayBase.o asynInt32ArraySyncIO.o asynInt64ArrayBase.o asynInt64ArraySyncIO.o asynUInt32DigitalBase.o asynUInt32DigitalSyncIO.o asynFloat64Base.o asynFloat64SyncIO.o asynFloat32ArrayBase.o asynFloat32ArraySyncIO.o asynFloat64ArrayBase.o asynFloat64ArraySyncIO.o asynOctetBase.o asynOctetSyncIO.o asynGenericPointerBase.o asynGenericPointerSyncIO.o asynEnumBase.o asynEnumSyncIO.o asynCommonSyncIO.o asynOptionSyncIO.o asynStandardInterfacesBase.o asynShellCommands.o asynInterposeCom.o asynInterposeEos.o asynInterposeFlush.o asynInterposeDelay.o asynInterposeEcho.o ParamListInvalidIndex.o ParamListParamNotFound.o ParamValNotDefined.o ParamValStringSizeRequestTooBig.o ParamValWrongType.o ParamValValueNotChanged.o paramVal.o asynPortDriver.o asynPortClient.o devAsynOctet.o asynEpicsUtils.o devAsynInt32.o devAsynInt8Array.o devAsynInt16Array.o devAsynInt32Array.o devAsynInt32TimeSeries.o devAsynUInt32Digital.o devAsynFloat64.o devAsynFloat32Array.o devAsynFloat64Array.o devAsynFloat64TimeSeries.o devAsynInt64Array.o devAsynInt64TimeSeries.o devAsynInt64.o asynRecord.o drvAsyn.o vxi11core_xdr.o drvVxi11.o E5810Reboot.o E2050Reboot.o TDS3000Reboot.o
devCommonGpib.o devSupportGpib.o boSRQonOff.o    -ldbRecStd -ldbCore -lca
-lCom  -ltirpc -lpthread    -lm -lrt -ldl -lgcc
collect2: error: ld returned 1 exit status
make[3]: *** [/home/epicsmgr/base-3.16.2/configure/RULES_BUILD:292:
libasyn.so] Error 1
make[2]: *** [/home/epicsmgr/base-3.16.2/configure/RULES_ARCHS:58:
install.linux-arm] Error 2
make[2] : on quitte le répertoire « /home/epicsmgr/support/asyn4-38/asyn »
make[1]: *** [/home/epicsmgr/base-3.16.2/configure/RULES_DIRS:84:
asyn.install] Error 2
make[1] : on quitte le répertoire « /home/epicsmgr/support/asyn4-38 »
make: *** [/home/epicsmgr/base-3.16.2/configure/RULES_DIRS:84: asyn.install] Error 2
Thank you very much for your attention to my problem.
Regards
Chaker Maazouzi
error building asyn4-38 : cross_compiler_target_archs=linux-arm chaker.maazouzi--- via Tech-talk
Prev: error building asyn4-38 : cross_compiler_target_archs=linux-arm chaker.maazouzi--- via Tech-talk
Next: RE: error building asyn4-38 : cross_compiler_target_archs=linux-arm 문건영(선형가속기팀) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
