1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Error while installing the StreamDevice
From: ZALA ARYANSINH via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk at aps.anl.gov
Date: Sun, 20 Feb 2022 23:50:29 +0530
Thanks a lot.
9737111609
On Sun, 20 Feb 2022, 4:22 am Mark Rivers, <rivers at cars.uchicago.edu> wrote:
Hi Zala,
You probably did not define ASYN correctly in StreamDevice/configure/RELEASE.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of ZALA ARYANSINH via Tech-talk
Sent: Saturday, February 19, 2022 2:50 AM
To: tech-talk at aps.anl.gov
Subject: Error while installing the StreamDevice
I am getting the following error while using make command for installing the StreamDevice.
make -C ./configure install
make[1]: Entering directory '/home/aryan/EPICS/support/StreamDevice/configure'
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/aryan/EPICS/support/StreamDevice/configure/O.linux-x86_64'
perl -CSD /home/aryan/EPICS/epics-base/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/home/aryan/EPICS/support/StreamDevice/configure/O.linux-x86_64'
make[1]: Leaving directory '/home/aryan/EPICS/support/StreamDevice/configure'
make -C ./src install
make[1]: Entering directory '/home/aryan/EPICS/support/StreamDevice/src'
make[2]: Entering directory '/home/aryan/EPICS/support/StreamDevice/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux    -DUSE_TYPED_RSET -DSTREAM_INTERNAL   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include          -I/home/aryan/EPICS/epics-base/include/compiler/gcc -I/home/aryan/EPICS/epics-base/include/os/Linux -I/home/aryan/EPICS/epics-base/include        -MM -MF AsynDriverInterface.d  ../AsynDriverInterface.cc
../AsynDriverInterface.cc:37:10: fatal error: asynDriver.h: No such file or directory
   37 | #include "asynDriver.h"
compilation terminated.
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux    -DUSE_TYPED_RSET -DSTREAM_INTERNAL   -O3 -g   -Wall      -mtune=generic      -m64  -fPIC -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include          -I/home/aryan/EPICS/epics-base/include/compiler/gcc -I/home/aryan/EPICS/epics-base/include/os/Linux -I/home/aryan/EPICS/epics-base/include        -c ../AsynDriverInterface.cc
make[2]: *** [/home/aryan/EPICS/epics-base/configure/RULES_BUILD:263: AsynDriverInterface.o] Error 1
make[2]: Leaving directory '/home/aryan/EPICS/support/StreamDevice/src/O.linux-x86_64'
make[1]: *** [/home/aryan/EPICS/epics-base/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/aryan/EPICS/support/StreamDevice/src'
make: *** [/home/aryan/EPICS/epics-base/configure/RULES_DIRS:85: src.install] Error 2
please help me with the same
Error while installing the StreamDevice ZALA ARYANSINH via Tech-talk
RE: Error while installing the StreamDevice Mark Rivers via Tech-talk
Prev: RE: Error while installing the StreamDevice Mark Rivers via Tech-talk
Next: RE: Epics Archiver Appliance and Network Storage slowdown Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Frequent disconnect and auto-reconnects with Serial ASYN and Stream controlled device Ashish Sharma via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
