1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: mrfioc2 error
To: [email protected]
Date: Tue, 22 Feb 2022 16:40:07 +0800 (GMT+08:00)
Hello! I used to use mrf-linux-driver from MRF. To load mrfioc2 IOC, I should delete pci_mrfevg and pci_mrfevr.
[root@localhost mrmShared]# lsmod |grep mrf
mrf                    18421  0
uio                    19338  1 mrf
parport                46395  1 mrf
pci_mrfevg             53731  0
pci_mrfevr             53731  0
As above, I want to delete pci_mrfevg and pci_mrfevr. I execute the following command to delete "pci_mrfevr.ko".
[root@localhost]# cd /lib/modules/3.10.0-1160.42.2.el7.x86_64/extra/
[root@localhost]# rm pci_mrfevg.ko
[root@localhost]# rm pci_mrfevr.ko
After restarting, there are still pcievg and pcievr. Some of the information displayed by the dmesg command is as follows:
[    1.343665] pci_mrfevr: loading out-of-tree module taints kernel.
[    1.343997] pci_mrfevr: module verification failed: signature and/or required key missing - tainting kernel
[    1.344404] Event Receiver PCI/PCIe driver init.
[    1.344659] mrfevr:BAR0 start df200000 end df23ffff, mmap 03700000
[    1.345275] mrfevr:BAR0 start df000000 end df03ffff, mmap 03780000
[    1.345581] Event Generator PCI/PCIe driver init.
[    1.346094] mrfevg:BAR0 start df100000 end df17ffff mmaped 03800000
  I would like to ask how to delete "pci_mrfevr.ko" and load mrfioc2 IOC successfully?
  Thank you for your time.I am looking forward to your reply.
Prev: Re: Frequent disconnect and auto-reconnects with Serial ASYN and Stream controlled device Zimoch Dirk (PSI) via Tech-talk
Next: Job opportunity at PSI: Group Leader Control Systems Schilcher Thomas (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: Frequent disconnect and auto-reconnects with Serial ASYN and Stream controlled device Ashish Sharma via Tech-talk
