On Thu, Mar 3, 2022 at 9:39 AM Hu, Yong via Tech-talk <[email protected]> wrote: This is a follow-up for this discussion: https://epics.anl.gov/tech-talk/2020/msg00382.php I'm glad you found the setting to make the old NFSv2 client work with a newer server OS. There is a nicer long term solution thanks to the folks at the Gemini Observatory and Chris Johns. rtems-libbsd now supports the FreeBSD NFSv4 client as well as the older NFSv2 client. The challenge for some EPICS users is that you may be using BSPs which only have NIC drivers for the legacy stack. Info was included at presentation at last summer's EPICS workshop (Chris) and at the Flight Software Workshop (me) on which BSPs we think you are using and the status of NIC drivers for each. There are many good reasons to want to move from the legacy stack to rtems-libbsd. The starting point is that it is currently based on the FreeBSD 12 release series and not 20 years old. It has many more features including IPV6, IPSEC, and packet filtering -- ignoring USB and SDIO. Easier to pull drivers from FreeBSD. And it has support for using the smarts and off loading capabilities of newer NICs. I'm happy you got this working but we'd be even happier to get the entire EPICS community moved to rtems-libbsd. I cc'ed Chris Johns and Gedare Bloom because all three of us would be happy to work with any EPICS user to get you moved to the new stack. --joel
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
