1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Possible bug??? in dbReadDatabaseFP
From: "Dudley, David via Tech-talk" <[email protected]>
Date: Thu, 3 Mar 2022 16:16:47 +0000
I wrote this little routine to allow me to load database records into the IOC upon startup.
// Set this to use 'tmpfile' to create a temprary file, or don't set to use tempname and create an actual file in /tmp
//#define USE_TMPFILE
void loadMyDatabaseRecords(void)
                char *pptr = NULL;
                char *subsPtr = NULL;
                FILE *tempFile = NULL;
                const char substring[] = "P=";
#ifndef USE_TMPFILE
                char nameTemplate[] = "BNET";
                char *tempName;
#endif
                /* Generate a temporary file, and write the database definition of the diagnostics record into it. */
#ifdef USE_TMPFILE
                tempFile = tmpfile();
#else
                tempName = tempnam(NULL, nameTemplate);
                printf("Opening %s\n",tempName);
                tempFile=fopen(tempName, "w+");
#endif
                if(tempFile) {
                                size_t i;
                                i=fputs(recordsDef, tempFile);
#ifdef USE_TMPFILE
                                // rewind the file to the start
                                rewind(tempFile);
#else
                                // If I'm using a file to do this, lets just close the file at the moment.
                                fclose(tempFile);
#endif
                                // Not quite ready yet, I need to fill out my "substitutions" buffer
                                pptr=getenv("IOCNAME");
                                i=strlen(substring)+strlen(pptr);
                                subsPtr = (char *) calloc(sizeof(char), i+1);
                                strncpy(subsPtr, substring, strlen(substring) );
                                strncat(subsPtr, pptr, strlen(pptr)+1);
#ifdef USE_TMPFILE
                                printf("Loading new database\n");
                                // use dbReadDatabaseFP to load the file
                                dbReadDatabaseFP(&pdbbase, tempFile, NULL, subsPtr);
#else
                                printf("Loading my temp file %s\n",tempName);
                                // use dbReadDatabase to load the file
                                dbReadDatabase(&pdbbase, tempName, NULL, subsPtr);
                                free(tempName);
#endif
                                printf("Done\n");
                                free(subsPtr);
                                printf("Closing file\n");
#ifdef USE_TMPFILE
                                // Closing the file will delete it as well.
                                fclose(tempFile);
#else
#endif
This is triggered during the iocInit startup during the initHookAtIocBuild state, and I’ve also tried it at the initHookAtBeginning state as well.
So, if I have ‘USE_TMPFILE’ defined, the routine uses ‘tmpfile’ and creates a temporary file, writes the database info to it, and then calls ‘dbReadDatabaseFP’.  If it’s not defined, the routine generates a temporary file, writes the database info into it, closes the file and uses ‘dbReadDatabase’ to load it.  There’s more maintenance needed in doing things with ‘dbReadDatabase’, but what the heck-
Now, here’s the rub…..
If I don’t define ‘USE_TMPFILE’, the routine generates a proper temporary file, writes a proper record to it, closes the file, etc… and calls ‘dbReadDatabase’ and works great.
If I do define ‘USE_TMPFILE’ (which was my original idea), it creates the temporary file, writes a proper record to it (I have checked this), and then calls ‘dbReadDatabaseFP’.
In this case, the IOC shows that it loaded the database, closed the file, and then I get a ‘free(): double free detected in tcache 2’ error and the IOC aborts.
This is with the latest version of EPICS 7 (just ‘git pull’d this morning, on Debian Bulldog.
Note that I’ve figured a way around this error, but want to report it just the same, in case this is a possible bug.
Later-
David Dudley
Controls Engineer III
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7133
Email: dudleyd@frib.msu.edu
cid:image002.jpg@01D07041.57B6D750
	char *pptr = NULL;
#ifndef USE_TMPFILE
	char *tempName;
#endif
#ifdef USE_TMPFILE
#else
#endif
	if(tempFile) {
		size_t i;
#ifdef USE_TMPFILE
		rewind(tempFile);
#else
		fclose(tempFile);
#endif
#ifdef USE_TMPFILE
#else
		free(tempName);
#endif
		printf("Done\n");
		free(subsPtr);
#ifdef USE_TMPFILE
		fclose(tempFile);
#else
#endif
Re: Possible bug??? in dbReadDatabaseFP Michael Davidsaver via Tech-talk
Prev: Re: RHEL8 as an NFS server for RTEMS Joel Sherrill via Tech-talk
Next: Re: Timing in seq record Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Next: Re: Possible bug??? in dbReadDatabaseFP Michael Davidsaver via Tech-talk
