1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Unknown error with an equipment
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: TONY YU <tonyyucom at gmail.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 17 Mar 2022 19:28:52 +0000
You should enable ASYN_TRACEIO_DRIVER for the IDEA port. That will show the actual messages sent and received.
Sent from my iPhone
On Mar 17, 2022, at 9:16 AM, TONY YU <tonyyucom at gmail.com> wrote:
Hello Mark,
It was working last month as least. Then there was a disaster with the server computer and I have to setup the server again with the database and protocol files. FYI, the broken computer was running with R 3.14.12.4 and the new computer is running with R 3.14.12.8.
Tony
Mark Rivers <rivers at cars.uchicago.edu> 於 2022年3月17日週四 下午7:42寫道:
Was this working previously?
It looks like the hardware is communicating OK but it is returning error codes.
Sent from my iPhone
> On Mar 17, 2022, at 8:25 AM, TONY YU via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Hello,
> I encountered an unsolvable error with one of my equipment. Below is the error and the corresponding st.cmd, db and proto files. I would like to know what causes this error message. Thanks in advance.
> error:
> IDEA ImpMik:IDEA:Status: Input "#31 hv error detect" mismatch after 4 bytes
> IDEA ImpMik:IDEA:Status: got "hv error detect" where "ok" was expected
> IDEA ImpMik:IDEA:SetFilterOn: Input "#2E impossible, erro" mismatch after 1 byte
> IDEA ImpMik:IDEA:SetFilterOn: got "2E impossible, error" where "0" was expected
> st.cmd:
> drvAsynIPPortConfigure("IDEA", "terminal.chamber6:10002")
> asynOctetSetInputEos("IDEA",0,"\r\n")
> asynOctetSetOutputEos("IDEA",0,"\r\n")
> dbLoadRecords("${TOP}/db/Impulsmikroskop/IDEA.db", "P=ImpMik, NAME=IDEA, interface=IDEA")
> IDEA.db:
> record(bi, "$(P):$(NAME):Status") {
>   field(PINI, "YES")
>   field(DTYP, "stream")
>   field(INP, "@IDEA.proto Get_Status $(interface)")
>   field(ZNAM, "ERR")
>   field(ONAM, "Ok")
> record(bo, "$(P):$(NAME):SetFilterOn") {
>   field(SCAN, "2 second")
>   field(FLNK, "$(P):$(NAME):SetEpass")
>   field(OUT, "@IDEA.proto Set_FilterOn $(interface)")
>   field(ZNAM, "Off")
>   field(ONAM, "On")
> IDEA.proto:
> terminator = CR LF;
> pollperiod = 10;
> replytimeout = 1000;
> readtimeout = 5000;
> # Get_Status
> Get_Status {
>     out "Get status";
>     in  "#%2i ok";
>     out "ver";
>     in "EFC_for_NanoESCA V01.03 B0115";
>     out "Set mode remote";
>     in "#04 remote mode";
> # Set_FilterOn
> # range: 1, 10
> Set_FilterOn {
>     out "Set filter %{off|on}";
>     in  "#0%*c filter %{off|on}";
>     @init {
>         out "Get filter";
> Best,
> Tony
Unknown error with an equipment TONY YU via Tech-talk
Re: Unknown error with an equipment Mark Rivers via Tech-talk
Re: Unknown error with an equipment TONY YU via Tech-talk
Prev: Re: Unknown error with an equipment TONY YU via Tech-talk
Next: Re: Unknown error with an equipment Andrew Johnson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
