Please
also consider setting
callbackParallelThreads
to enable
multiple concurrent threads to be working on the callback queues. Making the callback queue larger is one way, having the IOC process the callbacks faster is another way to cope with high traffic situations.
That's a good point. In this case the problem only occurs at iocInit because there are lots of records with SCAN=I/O Intr that get processed once at iocInit. In this case I think increasing the queue size is fine, it just means that iocInit takes a bit longer
to complete. In the case when the problem happens due to a high callback rate during normal operation then callbackParallelThreads is a better solution.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
Sent: Friday, March 18, 2022 4:54 PM
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Subject: Re: odd ASYN behavior
The problem was that the EPICS callback queue was overflowing. John was getting a lot of these errors:
callbackRequest: cbLow ring buffer full
By adding this command just before iocInit() the problem was fixed:
callbackSetQueueSize(10000)
This is normally not needed if the IOC is
controlling a single TetrAMM. However, John is controlling several TetrAMM devices from the same IOC, and that led to more callbacks than the default queue size could handle.
Please also consider setting
to enable multiple concurrent threads to be working on the callback queues. Making the callback queue larger is one way, having the IOC process the callbacks faster is another way to cope with high traffic situations.
See the AppDevGuide for more details [1].
There are iocShell commands to show statistics on queue usage to allow for checking as well as proper and safe queue size configuration. The iocStats module [2] can be used for continuous monitoring of queue status.
Cheers,
~Ralph
- odd ASYN behavior Runchey, John via Tech-talk
- Re: odd ASYN behavior Mark Rivers via Tech-talk
- Re: odd ASYN behavior Runchey, John via Tech-talk
- Re: odd ASYN behavior Ralph Lange via Tech-talk
Re: Unknown error with an equipment Mark Rivers via Tech-talk
<2022>
2025
Linking PVs to EGU field Marco A. Barra Montevechi Filho via Tech-talk
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
