1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: NDCodec Compression Factor
From: "Smith, William via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 22 Mar 2022 07:03:47 +0000
I have been revisiting using the NDCodec plugin in areaDetector. I noticed that when I try to repeat the example shown here https://cars9.uchicago.edu/software/epics/NDPluginCodec.html under “Screen Shots” with the following parameters plugin
#NDCodecConfigure(const char *portName, int queueSize, int blockingCallbacks, const char *NDArrayPort, int NDArrayAddr, int maxBuffers, size_t maxMemory, int priority, int stackSize)
NDCodecConfigure("CODEC1", 20, 0, "SIM1", 0, 0, 0, 0, 0, 5)
With the same settings as is shows in the example:
Compressor: Blosc
Blosc Compressor: ZSTD
Blosc Comp. Level: 5
Blosc Shuffle: Bit
Blosc num threads: 6
I can only achieve compression of something like 1.3 not 151.35 as is shown in the example. What might I be doing wrong?
If I use JPEG compression I can achieve higher compression ratios, e.g with JPEG quality set to 10 I get compression factor of 81.5. With anything other than JPEG, for all combinations of settings I get roughly the same compression factor between 1 and 2.
The input image is coming from the sim detector. I am using a 1024x 1024 image of UInt8 which is a single peak centred about (500,500).
There is no codec error shown. I get no error in the ioc shell.
Many thanks,
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Re: NDCodec Compression Factor Mark Rivers via Tech-talk
Prev: Only one network interface of three NF CA5351 Current Amplifiers is accessible Chiang, Liang-Chih [江良志] via Tech-talk
Next: Re: NDCodec Compression Factor Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: 回覆: Only one network interface of three NF CA5351 Current Amplifiers is accessible Chiang, Liang-Chih [江良志] via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
