1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: ScrollBar in Phoebus - cannot set $(pv_value) in script
From: Amien Crombie via Tech-talk <[email protected]>
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 24 Mar 2022 11:22:38 +0200
Hi
i'm using Phoebus and have a ScrollBar widget.
I'm using master 2021-07-29 17:51 Phoebus version running on my Ubuntu 20.04 pc. (jdk 16.02)
I however cannot set the scrollbar's value in my script.
Here a part of my python script :
from org.csstudio.display.builder.runtime.script import PVUtil
from org.csstudio.display.builder.runtime.script import ScriptUtil
print ("Dup Range")
scrollB = ScriptUtil.findWidgetByName(widget, "Scrollbar")
scrollB.setPropertyValue("$(pv_value)", 1.0)   #  I need to set my scrollBar to 1.0 after range change trigger..not working
and the following error I get:
2022-03-24 11:17:11 WARNING [org.csstudio.display.builder.runtime] Script execution failed
Display 'EmbeddedDisplay Embedded-Harp.bob', Widget 'Spinner_4' (choice), JythonScript Live/duplicate_range.py
Traceback (most recent call last):
  File "Live/duplicate_range.py", line 7, in <module>
    at org.csstudio.display.builder.model.Widget.getProperty(Widget.java:590)
    at org.csstudio.display.builder.model.Widget.setPropertyValue(Widget.java:722)
    at jdk.internal.reflect.GeneratedMethodAccessor5.invoke(Unknown Source)
    at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.base/java.lang.reflect.Method.invoke(Method.java:567)
java.lang.IllegalArgumentException: java.lang.IllegalArgumentException: Widget 'Scrollbar' (scrollbar) has no '$(pv_value)' property
Thanks
Amien Crombie (iThemba-LABS, South Africa)
Re: [EXTERNAL] ScrollBar in Phoebus - cannot set $(pv_value) in script Kasemir, Kay via Tech-talk
Prev: About checksum error 李姣赛 via Tech-talk
Next: motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: About checksum error Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] ScrollBar in Phoebus - cannot set $(pv_value) in script Kasemir, Kay via Tech-talk
