1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: Re: [EXTERNAL] ScrollBar in Phoebus - cannot set $(pv_value) in script
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: EPICS Tech-Talk <[email protected]>, Amien Crombie <[email protected]>
Date: Thu, 24 Mar 2022 14:18:55 +0000
> i .. have a ScrollBar widget.
That widget displays the value of a PV and writes to that same PV when the user moves the scrollbar
> I however cannot set the scrollbar's value in my script.
If for some reason you have to use a script,
you can set the value of a PV in that script,
and if that PV happens to be the PV of the scrollbar,
that scrollbar will then update:
# Script attached to scrollbar or other widget with PV
# pvs[0]: Some input PV
# Writes the value from the input PV to the PV of the widget
from org.csstudio.display.builder.runtime.script import PVUtil, ScriptUtil
value = PVUtil.getDouble(pvs[0])
pv = ScriptUtil.getPrimaryPV(widget)
pv.setValue(value)
ScrollBar in Phoebus - cannot set $(pv_value) in script Amien Crombie via Tech-talk
Prev: motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
Next: newbie question : one shot measurement Jérôme Poincheval via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: ScrollBar in Phoebus - cannot set $(pv_value) in script Amien Crombie via Tech-talk
Next: motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
