1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: motorRecord with phytron support: record send goto 0 command before reference is done
From: Kevin Peterson via Tech-talk <[email protected]>
To: Torsten Bögershausen <[email protected]>, "Bernhard.Kuner" <[email protected]>
Date: Tue, 29 Mar 2022 15:40:43 -0500
A better solution would be to modify the phytron driver to NOT set the limit bits of the MSTA if a home is in progress, for homing routines that use the limits:
https://github.com/epics-motor/motorPhytron/blob/9acb974257dc61512017f18f9b823be0495e948d/phytronApp/src/phytronAxisMotor.cpp#L1056-L1057
Those bits are why the motor record believes a limit is hit and the motion is done:
https://github.com/epics-modules/motor/blob/cc6c6a9b181691e8b04981c64ec99f8a887a937e/motorApp/MotorSrc/motorRecord.cc#L3693-L3694
Kevin
On 3/29/22 13:10, Torsten Bögershausen wrote:
I think that there may be a potential problem in the motorRecord itself.
The first one is that the record assumes that a motor is “done”,
when a limit switch is hit:
<https://github.com/epics-modules/motor/blob/master/motorApp/MotorSrc/motorRecord.cc#L3707>
While this may be true for some controllers, it is not, especially for modern controllers
that have a “homing sequence” which looks like
“hit the limit switch, once activated, revert and drive slowly until the switch is released”
I don’t have a Phytron to test this.
If you have time to modify the motorRecord itself and test, you can modify line 3707
from above.
motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
Re: motorRecord with phytron support: record send goto 0 command before reference is done Kevin Peterson via Tech-talk
Re: motorRecord with phytron support: record send goto 0 command before reference is done Bernhard.Kuner via Tech-talk
Re: motorRecord with phytron support: record send goto 0 command before reference is done Torsten Bögershausen via Tech-talk
Prev: Re: motorRecord with phytron support: record send goto 0 command before reference is done Torsten Bögershausen via Tech-talk
Next: Re: motorRecord with phytron support: record send goto 0 command before reference is done Kevin Peterson via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Next: Re: motorRecord with phytron support: record send goto 0 command before reference is done Bernhard Kuner via Tech-talk
