1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Static Build on armv7
From: Maren Purves via Tech-talk <tech-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: tech-talk at aps.anl.gov
Date: Wed, 30 Mar 2022 09:32:27 -1000
I wasn't talking about  renaming libraries but linking versions of the same one.
Done it many times.
On Wed, Mar 30, 2022 at 9:21 AM Michael Davidsaver
<mdavidsaver at gmail.com> wrote:
> On 3/30/22 11:57, Maren Purves wrote:
> > If you have a different version of /usr/lib/ld.so.1 you could  try a
> > soft link to there.
> > It quite often works.
> Please be careful with this.  Library names are different for a reason.
> Blindly renaming/linking shared libraries is setting yourself up for
> confusing error messages if your are lucky, and inexplicable corruption
> or crashes if you are not!
> > Maren
> > On Wed, Mar 30, 2022 at 8:02 AM Michael Davidsaver via Tech-talk
> > <tech-talk at aps.anl.gov> wrote:
> >> On 3/30/22 10:32, Florian Feldbauer wrote:
> >>> Hey Michael,
> >>> attached is the complete output from make and the readelf command you mentioned.
> >>   From the readelf output:
> >>> [Requesting program interpreter: /usr/lib/ld.so.1]
> >> If this file isn't present on target system, this is a sign that you are
> >> trying to use a toolchain for a (slightly) different target.  The best
> >> thing you can do is to sort out this incompatibility.
Re: Static Build on armv7 Michael Davidsaver via Tech-talk
Static Build on armv7 Florian Feldbauer via Tech-talk
Re: Static Build on armv7 Florian Feldbauer via Tech-talk
Re: Static Build on armv7 Maren Purves via Tech-talk
Prev: Re: Static Build on armv7 Michael Davidsaver via Tech-talk
Next: Re: Static Build on armv7 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
