Hi Asjish,
Since ImageJ works it looks like EPICS_CA_MAX_ARRAY_BYTES must be set OK on the IOC and on the ImageJ process. Are you sure it is also set OK on the caQtDM process?
It is not related to this problem, but I would suggest you consider migrating from aravisGigE to ADAravis (or ADSpinnaker). arabisGigE is no longer actively supported.
Sent: Thursday, March 31, 2022 1:09 AM
To: tech-talk <tech-talk at aps.anl.gov>; Mark Rivers <rivers at cars.uchicago.edu>
Subject: caQtDM caCamera widget not rendering images
Hello,
I am trying to add a new camera (FLIR's Blackfly S) into areaDetector (aravisGigE) with GUI on caQtDM. Earlier I had the attached GUI completely working with both ImageJ and caCamera widget able to render the images. But now after changes in my camera
processor board (new serial ID etc.), all things except for caCamera are working. X-Y profiles are working but caCamera is unable to render any image.
I have made no changes in the settings just replaced the earlier .edl and -feature.edl files (and also the .ui files) with new ones based on the xml config file of new camera.
Could you please help me here. I doubt on the caQtDm installation. Or anything else?
Thank you.
Ashish Sharma
Engineer 'D'
Inter-University Accelerator Centre,
Aruna Asaf Ali Marg, New Delhi - 110067
Mob. : +91-7982808263, +91-9868528158
Off. : 011-24126024 (Ext : 229 / 8804)
- Re: caQtDM caCamera widget not rendering images Ashish Sharma via Tech-talk
- caQtDM caCamera widget not rendering images Ashish Sharma via Tech-talk
Re: Static Build on armv7 Florian Feldbauer via Tech-talk
Re: Static Build on armv7 Michael Davidsaver via Tech-talk
<2022>
2025
<2022>
2025
ANJ, 14 Sep 2022 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
