On 3/31/22 01:50, Florian Feldbauer wrote:
$ cat configure/os/CONFIG.linux-arm.linux-arm
# CONFIG.linux-arm.linux-arm
# Definitions for native linux-arm builds
# Sites may override these definitions in CONFIG_SITE.linux-arm.linux-arm
# Include common gnu compiler definitions
include $(CONFIG)/CONFIG.gnuCommon
$ cat configure/os/CONFIG.linux-x86.linux-x86
# CONFIG.linux-x86.linux-x86
# Definitions for linux-x86 host - linux-x86 target builds
# Sites may override these definitions in CONFIG_SITE.linux-x86.linux-x86
STATIC_LDFLAGS_YES= -Wl,-Bstatic
STATIC_LDFLAGS_NO=
STATIC_LDLIBS_YES= -Wl,-Bdynamic
STATIC_LDLIBS_NO=
Adding those 4 last rows from CONFIG_SITE.linux-x86.linux-x86 to CONFIG_SITE.linux-arm.linux-arm solved my issue.
Now static build also works on armv7.
I think you are correct that passing both '-static' and '-Wl,-Bdynamic'
is a contradiction, which GCC unfortunately does not flag as an error.
Do you want to formulate this change as a pull request?
https://github.com/epics-base/epics-base/
I can't see exactly where, but "/lib/ld.so.1" must be used as a default
when no "-dynamic-linker ..." is passed to "ld". The valid values
for ARM are given here:
https://github.com/gcc-mirror/gcc/blob/0abc1cbad1687a887d754917927b6023e4dba3ce/gcc/config/arm/linux-eabi.h#L59-L65
fyi. these names actually appears in GCC's generated spec file(s), where
it can presumably be overwritten, if you understand spec files better than
I do...
https://gcc.gnu.org/onlinedocs/gcc/Spec-Files.html
gcc -dumpspecs|grep dynamic-linker
As I understand it, on amd64 it looks like all of the "-dynamic-linker ..."
are wrapped in a conditional "%{!static: ...}". So '-static' prevents
any from being passed to "ld".
Cheers,
Florian
Alternately, you could path Base to remove references to "-Wl,-Bdynamic",
which would result in a fully static executable (with the limitations
which this implies).
/usr/bin/g++ -o antelope -static -L/epics/base/lib/linux-arm -Wl,-rpath,/epics/base/lib/linux-arm -rdynamic closure.o error.o lalr.o lr0.o antelope.o mkpar.o output.o reader.o skeleton.o symtab.o verbose.o warshall.o -Wl,-Bdynamic -lpthread -lreadline -lm -lrt -ldl -lgcc
However, you may later encounter strange linker errors and/or crashes
if object code from different, somewhat incompatible, toolchains are
being linked together. So I would encourage you to investigate the
toolchain(s) first.
Cheers,
Florian
Am 30.03.2022 um 17:47 schrieb Michael Davidsaver:
On 3/30/22 07:15, Florian Feldbauer via Tech-talk wrote:
Hey all,
we use docker images to easily deploy our IOCs for our detector control system.
The images are build for amd64, arm64/aarch64 and armv7.
To reduce the size of those images, I recently switched from dynamic to static linking by adding the line
> && echo "STATIC_BUILD=YES" >> configure/CONFIG_SITE.local \
to our Dockerfile.
When compiling base7 for amd64 and aarch64 this is working just fine, but I get an error on arm/v7:
#0 189.7 Installing created executable /epics/base/bin/linux-arm/antelope
#0 190.1 /epics/base/bin/linux-arm/antelope -bparse -l -d ../flex/parse.y
#0 190.1 /usr/lib/ld.so.1: No such file or directory
#0 198.7 Expanding ../libComVersion.h@ to ../O.Common/libComVersion.h
I investigated the issue a bit closer and found the following:
root@195e454a8580:/epics/src/base# ldd /epics/base/bin/linux-arm/antelope
linux-vdso.so.1 (0x7ef10000)
libc.so.6 => /lib/arm-linux-gnueabihf/libc.so.6 (0x76e71000)
/usr/lib/ld.so.1 => /lib/ld-linux-armhf.so.3 (0x76f70000)
It looks like "STATIC_BUILD=YES" was ignored.
root@195e454a8580:/epics/src/base# ls /usr/lib/ld.so.1
ls: cannot access '/usr/lib/ld.so.1': No such file or directory
For some reason antelope gets linked against /usr/lib/ld.so.1 on armv7 but this file does not exist.
Does anyone know what causes this issue?
It would help if you could attach, or post somewhat, the complete
output of a clean 'make'.
Also the output of:
readelf -aW /epics/base/bin/linux-arm/antelope
Cheers,
Florian
- Static Build on armv7 Florian Feldbauer via Tech-talk
- Re: Static Build on armv7 Michael Davidsaver via Tech-talk
- Re: Static Build on armv7 Florian Feldbauer via Tech-talk
Re: caQtDM caCamera widget not rendering images Mark Rivers via Tech-talk
asyn trace masks on modbus reconnect John Dobbins via Tech-talk
<2022>
2025
caQtDM caCamera widget not rendering images Ashish Sharma via Tech-talk
<2022>
2025
