1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: caQtDM caCamera widget not rendering images
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Ashish Sharma <ashish.sharma at iuac.res.in>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Fri, 1 Apr 2022 12:33:14 +0000
> Could you please elaborate "Are you sure it is also set OK on the caQtDM process?" As to what variable to look for in this?
Just before you launch caQtDM, either manually or in a script, execute this command:
printenv EPIC_CA_MAX_ARRAY_BYTES
> Moreover, a detailed guide for installation and make it working using ADAravis and ADGenICam would be really helpful. Could you please provide a link?
The areaDetector documentation home page is here:
The installation Guide is here:
ADAravis documentation is here:
ADGenICam documentation is here:
> Another thing, is it advisable to install MEDM on Ubuntu 20.04 as lots of x11 packages have gotten obsolete for this version. We are working on EPICS7.
I have not used Ubuntu 20, but I have built medm on Ubuntu 18. areaDetector comes with screens for medm, edm, caQtDM, CSS/Boy and CSS/Phoebus.  Most of these are autoconverted from medm screens.
Sent: Friday, April 1, 2022 6:47 AM
To: Mark Rivers <rivers at cars.uchicago.edu>
Thanks Mark for quick response.
Thanks again
Ashish
To: "Ashish Sharma" <ashish.sharma at iuac.res.in>, "tech-talk" <tech-talk at aps.anl.gov>
Sent: Thursday, March 31, 2022 6:12:48 PM
Hi Asjish,
Since ImageJ works it looks like EPICS_CA_MAX_ARRAY_BYTES must be set OK on the IOC and on the ImageJ process.  Are you sure it is also set OK on the caQtDM process?
It is not related to this problem, but I would suggest you consider migrating from aravisGigE to ADAravis (or ADSpinnaker). arabisGigE is no longer actively supported.
Sent: Thursday, March 31, 2022 1:09 AM
To: tech-talk <tech-talk at aps.anl.gov>; Mark Rivers <rivers at cars.uchicago.edu>
Subject: caQtDM caCamera widget not rendering images
Hello,
I am trying to add a new camera (FLIR's Blackfly S) into areaDetector (aravisGigE) with GUI on caQtDM. Earlier I had the attached GUI completely working with both ImageJ and caCamera widget able to render the images. But now after changes in my camera processor board (new serial ID etc.), all things except for caCamera are working. X-Y profiles are working but caCamera is unable to render any image.
I have made no changes in the settings just replaced the earlier .edl and -feature.edl files (and also the .ui files) with new ones based on the xml config file of new camera.
Could you please help me here. I doubt on the caQtDm installation. Or anything else?
Thank you.
Ashish Sharma
Engineer 'D'
Inter-University Accelerator Centre,
Aruna Asaf Ali Marg, New Delhi - 110067
Mob. : +91-7982808263, +91-9868528158
Off. : 011-24126024 (Ext : 229 / 8804)
Re: caQtDM caCamera widget not rendering images Ashish Sharma via Tech-talk
Re: caQtDM caCamera widget not rendering images Mark Rivers via Tech-talk
Prev: Re: caQtDM caCamera widget not rendering images Ashish Sharma via Tech-talk
Next: Re: Communication error Francisco Ramos via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: caQtDM caCamera widget not rendering images Ashish Sharma via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
