Hi Marco,
On 4/12/22 8:39 AM, Marco A. Barra
Montevechi Filho via Tech-talk wrote:
I have an equipment which
has the HIGH field configurable in the hardware. We already have
a PV that reads it, but it is currently an entire PV, and not a
field of another existing PV.
Im trying to get that PV result and put it in the HIGH field of
another PV. Something like:
record(ai, "MY:PV") {
field(HIHI, 10)
field(HIGH, "ANOTHER:PV:HIGH:LIMIT PP")
field(LOW, -1)
field(LOLO, -5)
field(HHSV, MAJOR)
field(HSV, MINOR)
field(LSV, MINOR)
field(LLSV, MAJOR)
but each try of mine gets either syntax error or 'Can't set
"MY:PV.HIGH" to "ANOTHER:PV:HIGH:LIMIT"'. Am i doing something
wrong? Is this approach even possible?
To explain the "why" behind Torsten's answer, you can look up the
data type of the ai record's HIGH field on it's Record
Reference page:
Field |
Summary |
Type |
DCT |
Default |
Read |
Write |
CA PP |
HIHI |
Hihi Alarm Limit |
DOUBLE |
Yes |
Yes |
Yes |
Yes |
HIGH |
High Alarm Limit |
DOUBLE |
Yes |
Yes |
Yes |
Yes |
LOW |
Low Alarm Limit |
DOUBLE |
Yes |
Yes |
Yes |
Yes |
LOLO |
Lolo Alarm Limit |
DOUBLE |
Yes |
Yes |
Yes |
Yes |
The type given there is DOUBLE, so you can only set the field to a
value which is a double-precision floating point number — that's why
you were getting those errors, it can't accept a PV name. If you
want the high alarm limit of your ai record to be updated whenever
the value reported from the hardware changes you have to arrange for
some other record to copy the new value there. Torsten's ao record
demonstrates one way to do this (there are others which might be
appropriate in different circumstances):
record(ao,
"$(PREFIX)$(MOTOR_NAME)-CfgVELO-RB_")
field(PREC, "$(PREC)")
field(DOL,
"$(PREFIX)$(MOTOR_NAME)-CfgVELO-RB CP")
field(OUT,
"$(PREFIX)$(MOTOR_NAME).VELO")
field(OMSL,
"closed_loop")
The DOL and OUT fields of the ao
record type are both links; DOL is an INLINK (input link), so
it fetches a value from the record named in the field, and OUT is an
OUTLINK (output link), so it writes a value to the named record. The
CP flag at the end of the input link tells the record to monitor
that PV using Channel Access, and to cause the ao record to be
processed whenever the value changes thus sending the new value to
the other record. Using CP on an input link is normally better than
making the record process at some periodic rate because it will
process immediately, but only when it actually needs to.
- Andrew
Complexity is free, it's Simplicity that takes work.
- Dynamically changing HIHI PV field Marco A. Barra Montevechi Filho via Tech-talk
Re: Dynamically changing HIHI PV field Marco A. Barra Montevechi Filho via Tech-talk
Phoebus - xygraph print question Amien Crombie via Tech-talk
<2022>
2025
<2022>
2025
