1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: S_errno_ENOENT on loading motorUtils.db
From: Andrew Johnson via Tech-talk <tech-talk at aps.anl.gov>
To: Mrinal Bera <mrinalkb at uchicago.edu>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 19 Apr 2022 21:47:28 -0500
Hi Mrinal,
On 4/19/22 12:12 PM, Mrinal Bera via Tech-talk wrote:
Thanks to Mark Rivers and APS-BCDA Group, I could successfully build a new VME Crate system with EPICS 7.0.4 and vxWorks 6.9.4 with the following hardware configuration:
1) MVME 3100
2) MAXv 8000
3) OMS StepPak SPD-32M Motor Drivers
While booting the MVME board I am getting the following error while loading the motorUtils.db and couldnot figure out the reason.
epics> dbLoadRecords("$(MOTOR)/db/motorUtils.db","P=CRL15Sraight:")
filename="../dbStatic/dbLexRoutines.c" line number=271
S_errno_ENOENT dbRead opening file /home/epics/synApps/support/motor-R7-2-2/db/motorUtils.db
dbLoadRecords: failed to load '/home/epics/synApps/support/motor-R7-2-2/db/motorUtils.db'
That is a not-terribly friendly message that I think just means "file not found". You are loading an nfsCommands file but oes your VxWorks system have the /home/epics/synApps path mounted? Try typing
ls "/home/epics/synApps/support/motor-R7-2-2/db/motorUtils.db"
at the shell, my guess is that it won't be able to find it and that you will need to adjust what you're mounting, or maybe have the application install the file into its own db directory and load it from there.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: S_errno_ENOENT on loading motorUtils.db Mrinal Bera via Tech-talk
Prev: RE: drvModbusAsynConfigure exception 3 when ASLO and PREC fields of PV are changed Mark Rivers via Tech-talk
Next: Re: S_errno_ENOENT on loading motorUtils.db Mrinal Bera via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: S_errno_ENOENT on loading motorUtils.db Mrinal Bera via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
