1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Subject: S_errno_ENOENT on loading motorUtils.db
From: Mrinal Bera via Tech-talk <[email protected]>
Date: Tue, 19 Apr 2022 17:12:51 +0000
Dear All,
Thanks to Mark Rivers and APS-BCDA Group, I could successfully build a new VME Crate system with EPICS 7.0.4 and vxWorks 6.9.4 with the following hardware configuration:
1) MVME 3100
2) MAXv 8000
3) OMS StepPak SPD-32M Motor Drivers
While booting the MVME board I am getting the following error while loading the motorUtils.db and couldnot figure out the reason.
epics> dbLoadRecords("$(MOTOR)/db/motorUtils.db","P=CRL15Sraight:")
filename="../dbStatic/dbLexRoutines.c" line number=271
S_errno_ENOENT dbRead opening file /home/epics/synApps/support/motor-R7-2-2/db/motorUtils.db
dbLoadRecords: failed to load '/home/epics/synApps/support/motor-R7-2-2/db/motorUtils.db'
Can anyone help me to figure out the issue?
Other than this everything else loads successfully.
I am also attaching the st.cmd here.
Thanks and regards,
Mrinal
Mrinal Kanti Bera, PhD
NSF’s ChemMatCARS
University of Chicago
9700 S Cass Ave Bldg 434D
Argonne, IL-60439
United States
Phone: +1-630-252-0472
Attachment: st.cmd
Description: st.cmd
Re: S_errno_ENOENT on loading motorUtils.db Andrew Johnson via Tech-talk
Prev: drvModbusAsynConfigure exception 3 when ASLO and PREC fields of PV are changed Marco A. Barra Montevechi Filho via Tech-talk
Next: RE: drvModbusAsynConfigure exception 3 when ASLO and PREC fields of PV are changed Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  2026
Prev: Re: drvModbusAsynConfigure exception 3 when ASLO and PREC fields of PV are changed Marco A. Barra Montevechi Filho via Tech-talk
Next: Re: S_errno_ENOENT on loading motorUtils.db Andrew Johnson via Tech-talk
