Hi all,
I'm looking for the best AD module to base a new driver on.
I'm working with a new flat panel detector that receives commands, sends responses and sends data from three different ports on the same ip address using UDP. Each image is about 13MB and it can supposedly do 45 fps (585MB/s) on a 10 GB connection.
I would naively create three drvAsynIPPortConfigure one for each port but that's not how it is done in Pixirad and I'd like to avoid working directly with sockets if possible.
Can I use Mythen as a model and just make a "mythenConfig" that takes 3 ip ports? Is that not preferred for some reason? The approach I choose needs to handle 585MB/s.
Thanks, David
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
- RE: AreaDetector: device with 3 network ports Mark Rivers via Tech-talk
Re: Waveforms in Archiver Appliance Michael Davidsaver via Tech-talk
RE: [EXTERNAL] Re: Getting Permission denied messages while building Barrett (US), Patrick E via Tech-talk
<2022>
2025
2026
Re: Waveforms in Archiver Appliance John Dobbins via Tech-talk
<2022>
2025
2026
