1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: AreaDetector: device with 3 network ports
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: David Vine <dvine at sigray.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 21 Apr 2022 18:57:49 +0000
Hi David,
You could use this driver as an example:
https://github.com/epics-modules/quadEM/blob/master/quadEMApp/src/drvNSLS_EM.cpp
It creates 3 drvAsynIPPorts in the driver itself. One is UDP, 2 are TCP.  Using that approach you can just pass the IP address to the xxxConfigure command and constructor, and then the calls to drvAsynIPPortConfigure are done in the driver itself, not in the startup script.
I think this approach should work fine, you don’t need to use the raw socket calls.
I don’t remember why I used the raw socket calls for the Pixirad driver.  It may just be that I did not realize I could use drvAsynIPPort.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of David Vine via Tech-talk
Sent: Thursday, April 21, 2022 11:57 AM
To: tech-talk at aps.anl.gov
Subject: AreaDetector: device with 3 network ports
Hi all,
I'm looking for the best AD module to base a new driver on.
I'm working with a new flat panel detector that receives commands, sends responses and sends data from three different ports on the same ip address using UDP. Each image is about 13MB and it can supposedly do 45 fps (585MB/s) on a 10 GB connection.
I found an old message (https://epics.anl.gov/tech-talk/2017/msg00592.php) with some suggestions and the closest one it seems is Pixirad. But the pixirad creates on ip port in st.cmd and a direct socket connection for the data.
I would naively create three drvAsynIPPortConfigure one for each port but that's not how it is done in Pixirad and I'd like to avoid working directly with sockets if possible.
Can I use Mythen as a model and just make a "mythenConfig" that takes 3 ip ports? Is that not preferred for some reason? The approach I choose needs to handle 585MB/s.
David
Image removed by sender.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
AreaDetector: device with 3 network ports David Vine via Tech-talk
Prev: Re: Waveforms in Archiver Appliance John Dobbins via Tech-talk
Next: RE: Re: Getting Permission denied messages while building Barrett (US), Patrick E via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Prev: AreaDetector: device with 3 network ports David Vine via Tech-talk
Next: Controls Software Engineer / Python Developer (f/m/d) Steffen Hauf via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
