On 5/16/22 04:47, Nicklas Holmberg via Tech-talk wrote:
I am using pva input links for two different records, a longin and a bi record. The “longin” record works without any problem, but the “bi” does not.
This is the expected behavior of QSRV as currently defined.
A biRecord (enumeration with two labels) isn't the same as
a PVA boolean type. To map into bi or mbbi records, your
PVA server should provide an NTEnum.
The error shown in the IOC shell is:
pvaLink long int {anonymous}::pvaGetValue(DBLINK*, short int, void*, long int*) fails my-bi:pvapy-bool: castUnsafeV: Conversion not supported
which, of course, repeats every time the record is processed.
The PVs are served from a python pvapy application, and I have no problem reading them using general EPICS commands like pvget, pvinfo, etc. I use them as input links to the bi and longin records like this:
record(longin, "my-longin:pvapy-int"){
field(INP, {pva:{
pv:"plc-ts:PLC:ts_1252_ns",
proc:"CPP"
record(bi, "my-bi:pvapy-bool"){
field(INP, {pva:{
pv:"plc-ts:ptp:synchronized ",
proc:"CPP"
The IOC uses EPICS 7.0.6.1 and the following st.cmd:
#!/usr/bin/env iocsh.bash
dbLoadRecords("nsrecord.db")
iocInit()
Doing “pvinfo” on the incoming PVs show:
$ pvinfo plc-ts:ptp:synchronized
Server: 10.102.10.19:5075
Type:
epics:nt/NTScalar:1.0
boolean value
string descriptor
structure alarm
int severity
int status
string message
structure timeStamp
long secondsPastEpoch
int nanoseconds
int userTag
structure display
double limitLow
double limitHigh
string description
string format
string units
structure control
double limitLow
double limitHigh
double minStep
$ pvinfo plc-ts:PLC:ts_1252_ns
Type:
string value
string descriptor
structure alarm
int severity
int status
string message
structure timeStamp
int nanoseconds
int userTag
structure display
double limitLow
double limitHigh
string description
string format
string units
structure control
double limitLow
double limitHigh
double minStep
______________________
*Nicklas Holmberg*
Senior Engineer, ICS HWI
*European Spallation Source ERIC*
P.O. Box 176, SE-221 00 Lund, Sweden
Visiting address: Partikelgatan 2, 224 84 Lund
Mobile: +46 76 168 06 60
E-mail: nicklas.holmberg at ess.eu <mailto:nicklas.holmberg at ess.eu>__
ess.eu <ess.eu>__
- RE: Conversion error when using (pvapy served) PVA input link in a "bi" record Nicklas Holmberg via Tech-talk
- Conversion error when using (pvapy served) PVA input link in a "bi" record Nicklas Holmberg via Tech-talk
Segmentation fault (core dumped) Error cl47cl--- via Tech-talk
<2022>
<2022>
