1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: issue with procserv
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 23 May 2022 10:59:20 +0200
Hi Ralph,
I actually feared, that is has nothing to do with procserv or the ioc itself.
Unfortunately I'm not an expert for systemd myself, but I hope someone in this forum has some ideas....
Cheers,
Florian
On 5/23/22 10:54, Ralph Lange via Tech-talk wrote:
Hi Florian,
Doesn't the third line of your log
On Mon, 23 May 2022 at 10:32, Florian Feldbauer via Tech-talk <[email protected]> wrote:
Hey all,
I currently have a problem with procserv.
I'm using the latest commit from github compilied on Raspbian OS bullseye.
I used manage-procs to create a service but the service gets stopped
every now and then.
The actual runtime seems to be quite arbitrary. Sometimes a few secs
sometimes several hours.
The log output does not really contain any helpfull information.
Any idea what could causing procserv to shut down?
CPU and RAM usage are way below 10% when the IOC is running.
Cheers,
Florian
pi@scatterchamber:~ $ systemctl --user status procserv-epicsioc.service
● procserv-epicsioc.service - procServ for epicsioc
      Loaded: loaded
(/home/pi/.config/procServ.d/procserv-epicsioc.service; enabled; vendor
preset: enabled)
      Active: inactive (dead)
May 23 10:10:17 scatterchamber procserv-epicsioc[58686]: 2022/05/23
10:10:17.505 drvModbusAsyn::doModbusIO port chillerReadReg error calling
writeRead, error=PilotONE-187144:502 TCP timeout>
May 23 10:10:18 scatterchamber procserv-epicsioc[58686]: 2022/05/23
10:10:18.604 drvModbusAsyn::doModbusIO port chillerReadReg writeRead
status back to normal having had 1 errors, nwrite=6/>
i.e., the next one
May 23 10:10:45 scatterchamber systemd[58650]: Stopping procServ for
epicsioc...
May 23 10:10:45 scatterchamber procserv-epicsioc[58686]: @@@ Current
time: Mon May 23 10:10:45 2022
May 23 10:10:45 scatterchamber procserv-epicsioc[58686]: @@@ Child
process is shutting down, a new one will be restarted shortly
May 23 10:10:45 scatterchamber procserv-epicsioc[58686]: @@@ ^R or ^X
restarts the child, ^Q quits the server, ^D closes this connection
procserv-epicsioc.service: Succeeded.
May 23 10:10:45 scatterchamber systemd[58650]: Stopped procServ for
epicsioc.
procserv-epicsioc.service: Consumed 1.799s CPU time.
suggest that systemd is deliberately shutting down the IOC?
The following log lines definitely look like procServ was told to shut down the child process.
I'm not a systemd expert enough to know what could cause that (wrong dependencies between services maybe?), but this doesn't really look like something originating within procServ or the child process.
Cheers,
~Ralph
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Re: issue with procserv Johnson, Andrew N. via Tech-talk
Re: issue with procserv montis via Tech-talk
issue with procserv Florian Feldbauer via Tech-talk
Re: issue with procserv Ralph Lange via Tech-talk
Prev: Re: issue with procserv Ralph Lange via Tech-talk
Next: Re: issue with procserv Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
