1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Ability to change a record in an IOC when another IOC is exited
From: Ralph Lange via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Tue, 24 May 2022 17:29:26 +0200
On Tue, 24 May 2022 at 17:26, Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov> wrote:
On 5/24/22 08:20, Wang, Andrew via Tech-talk wrote:
> Hi all,
> Suppose I have an IOC called foo that contains an analog input record called foo_record and I have another IOC called bar. Is there a possible way to input a value into foo_record when bar is exited? For instance, if I exit bar, I want foo_record to have a certain value.
A link with the CP modifier will alarm with INVALID severity while disconnected.
And you can use that in combination with the IVOA/IVOV mechanics of an output record to write a specific value into a specific place.
Ability to change a record in an IOC when another IOC is exited Wang, Andrew via Tech-talk
Re: Ability to change a record in an IOC when another IOC is exited Michael Davidsaver via Tech-talk
Prev: Re: Ability to change a record in an IOC when another IOC is exited Michael Davidsaver via Tech-talk
Next: Re: procServer unix socket configuration Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: StreamDevice protocol file to skip over the header string when get waveform MuYuan Wang via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
