1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 26 May 2022 21:48:24 +0000
Ø  At the top of freeListLib.c add:
Ø  #define EPICS_FREELIST_DEBUG
I did that and rebuilt base and synApps.
The error is the same:
ioc13lab2>
VME Bus Error accessing A16: 0x347e
machine check
Exception next instruction address: 0x0368cf38
Machine Status Register: 0x0008b032
Condition Register: 0x48000884
Task: 0x4441190 "CAS-event"
0x4441190 (CAS-event): task 0x4441190 has had a failure and has been stopped.
0x4441190 (CAS-event): The task has been terminated because it triggered an exception that raised the signal 10.
ioc13lab2> tt  0x4441190
0x0012489c vxTaskEntry  +0x48 : epicsThreadEntry ()
0x036a8f18 epicsThreadEntry+0x80 : 0x036073f8 ()
0x036076d0 db_start_events+0x458: db_delete_field_log ()
0x03606be0 db_delete_field_log+0x54 : freeListFree ()
value = 0 = 0x0
Other ideas of how to debug it?
-----Original Message-----
From: Michael Davidsaver <mdavidsaver at gmail.com>
Sent: Thursday, May 26, 2022 4:26 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Cc: tech-talk at aps.anl.gov
Subject: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
On 5/26/22 14:00, Mark Rivers wrote:
> It looks like freeListFree() is probably generating an access violation.
If so, this would almost certainly be a sign of a bug elsewhere.
(double free, free of stack, ...)
Bypassing freeListLib _might_ give some added insight, or perhaps change the fault in some way.
This will short circuit the free list code, to always call malloc() and free().
Or more specifically, callocMustSucceed(), you would find out if any allocation requests are failing.
https://github.com/epics-base/epics-base/blob/3fadf4a26cfe33dcb9eb9e4620634e1d3a7b9763/modules/libcom/src/freeList/freeListLib.c#L63-L65
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules J. Lewis Muir via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Prev: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Next: Re: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules J. Lewis Muir via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
