Yes, i using till’s configuration
Kristi
Sent from my iPhone
> On May 26, 2022, at 9:33 AM, Michael Davidsaver <mdavidsaver at gmail.com> wrote:
> On 5/25/22 14:15, Michael Davidsaver wrote:
>> Indeed this appears to be the case. There is an std::map used to track
>> which PVA servers have sent beacons. Entries are added, but never removed.
>> Each entry has a Mutex (this code does very granular locking...).
> I also notice that a temporary Mutex is allocated
> while processing each search message. Not a leak,
> but also not so efficient.
> I've been playing around with "bpftrace" as an
> alternative to "systemtap". (imo. systemtap is
> great, but decoding its error messages is no fun)
> https://github.com/iovisor/bpftrace/blob/master/docs/reference_guide.md
>> $ cat rxmutex.bpf
>> // Print user stack trace when epicsMutexOsiCreate() called through processBuffer()
>> // unmangled name...
>> // epics::pvAccess::BlockingUDPTransport::processBuffer(
>> // std::shared_ptr<epics::pvAccess::Transport> const&, osiSockAddr&,
>> // osiSockAddr& fromAddress, ByteBuffer* receiveBuffer)
>> uprobe:"/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5":_ZN5epics8pvAccess20BlockingUDPTransport13processBufferERKSt10shared_ptrINS0_9TransportEER11osiSockAddrPNS_6pvData10ByteBufferE
>> @inproc[tid] = 1;
>> uretprobe:"/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5":_ZN5epics8pvAccess20BlockingUDPTransport13processBufferERKSt10shared_ptrINS0_9TransportEER11osiSockAddrPNS_6pvData10ByteBufferE
>> delete(@inproc[tid]);
>> uprobe:"/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1":epicsMutexOsiCreate
>> if(@inproc[tid]) {
>> printf("==============\n%s\n", ustack(perf));
> Why yes, that c++ mangled symbol name is 127 characters long...
>> $ sudo bpftrace -p `pgrep softIocPVA` rxmutex.bpf
>> Attaching 3 probes...
> While running "pvget"
>> 7f474e0e2d53 epicsMutexOsiCreate+0 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
>> 7f474dbad4dc epics::pvAccess::ServerChannelFindRequesterImpl::ServerChannelFindRequesterImpl(std::shared_ptr<epics::pvAccess::ServerContextImpl> const&, std::shared_ptr<epics::pvAccess::PeerInfo const> const&, int)+308 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>> 7f474dbaced7 epics::pvAccess::ServerSearchHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+1897 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>> 7f474dbac094 epics::pvAccess::ServerResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+380 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>> 7f474db420b8 epics::pvAccess::BlockingUDPTransport::processBuffer(std::shared_ptr<epics::pvAccess::Transport> const&, osiSockAddr&, epics::pvData::ByteBuffer*)+736 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>> 7fffffffe000 0x7fffffffe000 ([unknown])
>> 7f474e0e1869 epicsThreadCallEntryPoint+97 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
>> 7f474e0e9d96 start_routine+431 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
>> 7f474d764ea7 start_thread+215 (/usr/lib/x86_64-linux-gnu/libpthread-2.31.so)
> While running another PVA server
>> 7f474db49e68 epics::pvAccess::BeaconHandler::BeaconHandler(std::shared_ptr<epics::pvAccess::Context> const&, osiSockAddr const*)+86 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>> 7f474db8c2cc (anonymous namespace)::InternalClientContextImpl::getBeaconHandler(osiSockAddr*)+244 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>> 7f474db83bfc (anonymous namespace)::BeaconResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+678 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>> 7f474db85b8d (anonymous namespace)::ClientResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+349 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
- Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
<2022>
2025
<2022>
2025
