1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Can't create mutex semaphore: too many
From: "Luchini, Kristi L. via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: Joel Sherrill <[email protected]>, Talk EPICS Tech <[email protected]>
Date: Thu, 26 May 2022 21:57:08 +0000
Yes, i  using Till’s RTEMS configuration.
Kristi
Sent from my iPhone
> On May 26, 2022, at 9:33 AM, Michael Davidsaver <[email protected]> wrote:
> On 5/25/22 14:15, Michael Davidsaver wrote:
>> Indeed this appears to be the case.  There is an std::map used to track
>> which PVA servers have sent beacons.  Entries are added, but never removed.
>> Each entry has a Mutex (this code does very granular locking...).
> I also notice that a temporary Mutex is allocated
> while processing each search message.  Not a leak,
> but also not so efficient.
> I've been playing around with "bpftrace" as an
> alternative to "systemtap".  (imo. systemtap is
> great, but decoding its error messages is no fun)
> https://github.com/iovisor/bpftrace/blob/master/docs/reference_guide.md
>> $ cat rxmutex.bpf
>> // Print user stack trace when epicsMutexOsiCreate() called through processBuffer()
>> // unmangled name...
>> // epics::pvAccess::BlockingUDPTransport::processBuffer(
>> //  std::shared_ptr<epics::pvAccess::Transport> const&, osiSockAddr&,
>> //  osiSockAddr& fromAddress, ByteBuffer* receiveBuffer)
>> uprobe:"/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5":_ZN5epics8pvAccess20BlockingUDPTransport13processBufferERKSt10shared_ptrINS0_9TransportEER11osiSockAddrPNS_6pvData10ByteBufferE
>>    @inproc[tid] = 1;
>> uretprobe:"/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5":_ZN5epics8pvAccess20BlockingUDPTransport13processBufferERKSt10shared_ptrINS0_9TransportEER11osiSockAddrPNS_6pvData10ByteBufferE
>>    delete(@inproc[tid]);
>> uprobe:"/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1":epicsMutexOsiCreate
>>    if(@inproc[tid]) {
>>        printf("==============\n%s\n", ustack(perf));
> Why yes, that c++ mangled symbol name is 127 characters long...
>> $ sudo bpftrace -p `pgrep softIocPVA` rxmutex.bpf
>> Attaching 3 probes...
> While running "pvget"
>>        7f474e0e2d53 epicsMutexOsiCreate+0 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
>>        7f474dbad4dc epics::pvAccess::ServerChannelFindRequesterImpl::ServerChannelFindRequesterImpl(std::shared_ptr<epics::pvAccess::ServerContextImpl> const&, std::shared_ptr<epics::pvAccess::PeerInfo const> const&, int)+308 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>>        7f474dbaced7 epics::pvAccess::ServerSearchHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+1897 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>>        7f474dbac094 epics::pvAccess::ServerResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+380 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>>        7f474db420b8 epics::pvAccess::BlockingUDPTransport::processBuffer(std::shared_ptr<epics::pvAccess::Transport> const&, osiSockAddr&, epics::pvData::ByteBuffer*)+736 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>>        7fffffffe000 0x7fffffffe000 ([unknown])
>>        7f474e0e1869 epicsThreadCallEntryPoint+97 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
>>        7f474e0e9d96 start_routine+431 (/home/mdavidsaver/work/epics/base-git/lib/linux-x86_64-debug/libCom.so.3.21.1)
>>        7f474d764ea7 start_thread+215 (/usr/lib/x86_64-linux-gnu/libpthread-2.31.so)
> While running another PVA server
>>        7f474db49e68 epics::pvAccess::BeaconHandler::BeaconHandler(std::shared_ptr<epics::pvAccess::Context> const&, osiSockAddr const*)+86 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>>        7f474db8c2cc (anonymous namespace)::InternalClientContextImpl::getBeaconHandler(osiSockAddr*)+244 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>>        7f474db83bfc (anonymous namespace)::BeaconResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+678 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
>>        7f474db85b8d (anonymous namespace)::ClientResponseHandler::handleResponse(osiSockAddr*, std::shared_ptr<epics::pvAccess::Transport> const&, signed char, signed char, unsigned long, epics::pvData::ByteBuffer*)+349 (/home/mdavidsaver/work/epics/pv/pvAccess/lib/linux-x86_64-debug/libpvAccess.so.7.1.5)
Re: Can't create mutex semaphore: too many Michael Davidsaver via Tech-talk
Prev: Re: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
Next: Re: Can't create mutex semaphore: too many Luchini, Kristi L. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
