On 5/27/22 06:17, Mark Rivers wrote:
Hi Michael,
I commented out all lines in recGbl.c that reference the new amsg and namsg fields. That did not fix the problem.
I take this to mean both db_post_events() and epicsVsnprintf() calls,
which means that both AMSG and NAMSG should always be an empty string.
(aka. char[40] all nils)
https://github.com/epics-base/epics-base/commit/892a361de7002bf2b3f375f24bc5bf61858de2e5
On 5/27/22 10:33, Mark Rivers wrote:
I am now using the unmodified 7.0.6 release.
Before I build in that directory I run
I don't know how difficult it is with vxWorks @APS, but it might be a
good idea to go further and start from fresh git-clone of all modules
(base and synapps and application). This should rule out build
leftovers entirely.
What could possibly cause this?
This is a very good question...
As I think about it, adding/removing AMSG+NAMSG would have exposed some
partial rebuild problems with Base and parts of synapps. The generated
record type headers include a check that the number of fields at load time
is the same as the number at build time.
If not a build/ABI issue, I don't see an easy way forward in troubleshooting.
We've passed the point where I would be trying to setup a (remote) debugger
to inspect the stack of a faulting thread. This should identify one of the
records involved, and a dump of that record struct may show evidence of corruption.
For that matter, "dbpr <name> 5" could show evidence, if you can find one
of the records.
- RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
- Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
<2022>
2025
<2022>
2025
