1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Subject: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: Mark Rivers <rivers at cars.uchicago.edu>, Torsten Bögershausen <Torsten.Bogershausen at ess.eu>, Benjamin Franksen <benjamin.franksen at helmholtz-berlin.de>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 1 Jun 2022 12:03:23 -0700
On 6/1/22 10:54, Mark Rivers wrote:
Both of those commits were part of this PR https://github.com/epics-base/epics-base/pull/99 <https://github.com/epics-base/epics-base/pull/99>
One of the comments on that PR (January 27, 2021) was:
We expect to be nervous about this change because of the complex area it's working in, so we will merge it /after/ the next release which should be before the Codeathon in March, but we don't see anything obviously wrong with it.
This PR was recognized as having a high risk change of regression.
The code involved is some of the most complex in Base.  (Try to
follow all of the possible paths through dbGet() )
This change was judged to be worthwhile since it actually reduces
that complexity.  Sadly, we don't get many PRs with a net reduction
in source line count.
Merging after the 7.0.5 release, and before the 2021 codeathon,
was an attempt to mitigate this risk by maximizing the amount
of testing before 7.0.6.
Unfortunately, this seems not to have been enough.
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Torsten Bögershausen via Tech-talk
Prev: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Next: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <20222023  2024  2025
Next: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
ANJ, 14 Sep 2022 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
