1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Subject: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules
From: Till Straumann via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, Mark Rivers <[email protected]>
Date: Thu, 2 Jun 2022 09:29:25 +0200
Just one comment in-line below (no, there is no compiler error).
On 6/2/22 05:24, Michael Davidsaver wrote:
On 6/1/22 14:50, Mark Rivers wrote:
I checked out R7.0.6.1 and made the following change to dbEvent.c  It checks whether pfl or pfl->u.r.dtor are in the VME A32 address space.  If they are it prints an error and returns.
So, these addresses appear in pfl->u.r.dtor or eg. pfl->u.v.field.dbf_float
My question is then which part(s) of the db_field_log struct have incorrect values?
(eg. "\xbf\x3e\x00\x1e" as float32 is -0.74)
One straightforward, though a bit tedious, think to do would be to print a
dump of the contents of the db_field_log.  eg. I'd be interested to know
if db_field_log::time appears valid.
After making that change then one time when I started the IOC I got these messages right after iocInit, which is not when it usually fails.
This makes me wonder if these "addresses" are eg. somehow valid ADC values, which just happen to track through the VME window sometimes. Though if you've
only loading soft records, I don't see how this could be.
Further, I still don't see how these values aren't appearing in the register dump.
I don't think PPC has any instructions which do a double indirection.
Another odd ball idea which occurs to me is that maybe the compiler is mishandling the db_field_log::type bit field.  The dbEvent.o which you send to Till and I has:
      4c:       80 1f 00 00     lwz r0,0(r31)
      50:       2f 80 00 00     cmpwi   cr7,r0,0
If I read things correctly, I think this is meant to correspond to
'pfl->u.r.type==dbfl_type_val==0", however it is testing the whole word, and would mis-trigger because 'pfl->u.r.ctx == dbfl_context_event == 1` for a monitor update.
The compilation is actually correct. I paste the complete statement here
      54:    40 9c 00 18     bge     cr7,6c <db_delete_field_log+0x38>
Note that u.r.type is a 1-bit bit-field at the leftmost position. So the 'bge' (branch if greater or equal) tests exactly that bit, i.e., if the bit is *not* set it does not branch and proceeds to test pfl->u.r.dtor
When I look at the result of a local RTEMS build, I think the corresponding is:
   8:   89 24 00 00     lbz     r9,0(r4)
   c:   71 29 00 80     andi.   r9,r9,128
Which is testing the high bit as it should.
For completeness.  Disassembly of db_delete_field_log() from dbEvent.o.
Note that this is object code, with incomplete relocations.
00000034 <db_delete_field_log>:
      34:       94 21 ff f0     stwu    r1,-16(r1)
      38:       7c 08 02 a6     mflr    r0
      3c:       93 e1 00 0c     stw     r31,12(r1)
      40:       7c 7f 1b 79     mr.     r31,r3
      44:       90 01 00 14     stw     r0,20(r1)
      48:       41 82 00 40     beq     88 <db_delete_field_log+0x54>
      58:       80 1f 00 18     lwz     r0,24(r31)
      5c:       2f 80 00 00     cmpwi   cr7,r0,0
      60:       41 9e 00 0c     beq     cr7,6c <db_delete_field_log+0x38>
      64:       7c 09 03 a6     mtctr   r0
      68:       4e 80 04 21     bctrl
      6c:       3d 20 00 00     lis     r9,0
      70:       7f e4 fb 78     mr      r4,r31
      74:       80 69 00 00     lwz     r3,0(r9)
      78:       3d 20 00 00     lis     r9,0
      7c:       39 29 00 00     addi    r9,r9,0
      80:       7d 29 03 a6     mtctr   r9
      84:       4e 80 04 21     bctrl
      88:       80 01 00 14     lwz     r0,20(r1)
      8c:       83 e1 00 0c     lwz     r31,12(r1)
      90:       38 21 00 10     addi    r1,r1,16
      94:       7c 08 03 a6     mtlr    r0
      98:       4e 80 00 20     blr
From my local build for RTEMS-mvme3100
void db_delete_field_log (db_field_log *pfl)
    if (pfl) {
   0:   7c 64 1b 79     mr.     r4,r3
   4:   4d 82 00 20     beqlr
        /* Free field if reference type field log and dtor is set */
        if (pfl->type == dbfl_type_ref && pfl->u.r.dtor) pfl->u.r.dtor(pfl);
  10:   40 82 00 10     bne     20 <db_delete_field_log+0x20>
        /* Free the field log chunk */
        freeListFree(dbevFieldLogFreeList, pfl);
  14:   3d 20 00 00     lis     r9,0
  18:   80 69 00 00     lwz     r3,0(r9)
  1c:   48 00 00 00     b       1c <db_delete_field_log+0x1c>
  20:   81 24 00 50     lwz     r9,80(r4)
  24:   2f 89 00 00     cmpwi   cr7,r9,0
  28:   41 be ff ec     beq     cr7,14 <db_delete_field_log+0x14>
  2c:   94 21 ff f0     stwu    r1,-16(r1)
  30:   7c 08 02 a6     mflr    r0
  34:   7d 29 03 a6     mtctr   r9
  38:   90 01 00 14     stw     r0,20(r1)
  3c:   90 81 00 08     stw     r4,8(r1)
  40:   4e 80 04 21     bctrl
  44:   80 01 00 14     lwz     r0,20(r1)
  48:   3d 20 00 00     lis     r9,0
  4c:   80 81 00 08     lwz     r4,8(r1)
  50:   80 69 00 00     lwz     r3,0(r9)
  54:   7c 08 03 a6     mtlr    r0
  58:   38 21 00 10     addi    r1,r1,16
  5c:   48 00 00 00     b       5c <db_delete_field_log+0x5c>
Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Michael Davidsaver via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Torsten Bögershausen via Tech-talk
Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Till Straumann via Tech-talk
Prev: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
Next: Re: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  <2022>  2023  2024  2025  2026
Prev: Re: [EXTERNAL] Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Hartman, Steven via Tech-talk
Next: RE: Bus errors accessing VME with base 7.0.6.1 and latest synApps modules Mark Rivers via Tech-talk
